Golden Eagle Vtec kit with a B20 Botton end?
Old Aug 6, 2007 | 12:45 PM
Coolest Dude Ever's Avatar
Default Golden Eagle Vtec kit with a B20 Botton end?
B20 85mm.
B16 head
I purchased the Golden Eagle kit with a 85mm P30 head gasket.
Will it work? i was under the impression that it will. But have heard from a few people that it will leak.
WTF?
Any input.
Old Aug 6, 2007 | 12:54 PM
1.8L_allmotormilitia's Avatar
If the block is 85mm and you purchased the 85mm head gasket then you're set.
And about the leaking.. if its installed right nothing will go wrong.
Old Aug 6, 2007 | 01:05 PM
Default Re: (1.8L_allmotormilitia)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1.8L_allmotormilitia &raquo;</TD></TR><TR><TD CLASS="quote">If the block is 85mm and you purchased the 85mm head gasket then you're set.
And about the leaking.. if its installed right nothing will go wrong.</TD></TR></TABLE>
Thats what i thought. Everyone is just freaking me out haha.
Thanks.
Old Aug 6, 2007 | 01:10 PM
mar778c's Avatar
Community Builder
Community Influencer
Default Re: Golden Eagle Vtec kit with a B20 Botton end? (Coolest Dude Ever)
Most people use a LS headgasket. See here:https://honda-tech.com/zerothread/1676914
Old Aug 6, 2007 | 04:20 PM
Default Re: Golden Eagle Vtec kit with a B20 Botton end? (mar778c)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mar778c &raquo;</TD></TR><TR><TD CLASS="quote">Most people use a LS headgasket. See here:https://honda-tech.com/zerothread/1676914</TD></TR></TABLE>
Old Aug 6, 2007 | 09:38 PM
SYTFU Tommy.'s Avatar
why would he use a LS headgasket on a B20? the piston size are different, got to rememebr that.
Old Aug 6, 2007 | 10:35 PM
Default Re: Golden Eagle Vtec kit with a B20 Botton end? (SYTFU Tommy.)
cuz the LS gasket is bored to 85mm like i stated above.
Old Aug 6, 2007 | 10:39 PM
refering to mar778c
Old Aug 7, 2007 | 05:11 AM
mar778c's Avatar
Community Builder
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SYTFU Tommy. &raquo;</TD></TR><TR><TD CLASS="quote">why would he use a LS headgasket on a B20? the piston size are different, got to rememebr that.</TD></TR></TABLE>
With the correct bore, the gasket will not leak oil. Please go to the link I posted. it is filled with correct information.
Old Aug 7, 2007 | 11:33 AM
Koolaid_Chris's Avatar
if the b20 is 85mm as well the golden eagel head gasket it should work out perfect
Old Aug 17, 2007 | 08:56 AM
djmatix's Avatar
you guys are whacked. The b20 is 84mm bore!!
Old Aug 17, 2007 | 09:48 AM
Golden Eagle's Avatar
Default Re: (djmatix)
we don't use the ls gaskets because we found the the vtec gaskets work better no leaks at al you will be fine
Old Aug 17, 2007 | 12:29 PM
h22crxpwr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Coolest Dude Ever &raquo;</TD></TR><TR><TD CLASS="quote">B20 85mm.
B16 head
WTF?
Any input. </TD></TR></TABLE>
people who tell you crap like " i heard it will leak" have never used it. don't listen to them... too many people who think they know it all because they heard that someones uncles brothers roommate had one that leaked. you will be fine.
Golden eagle
Old Aug 17, 2007 | 12:33 PM
CARMA_626's Avatar
I drive a G35, it's silver, surprised?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by djmatix &raquo;</TD></TR><TR><TD CLASS="quote">you guys are whacked. The b20 is 84mm bore!!</TD></TR></TABLE>
His engine was bored out to 85mm.
Old Aug 17, 2007 | 01:46 PM
Rice-aronie's Avatar
read?
Old Aug 23, 2007 | 05:59 AM
djmatix's Avatar
Default Re: (Rice-aronie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rice-aronie &raquo;</TD></TR><TR><TD CLASS="quote">
read?</TD></TR></TABLE>
My apologies. Anyone who states their b20 is 85mm without saying "b20 bored to 85mm" usually has no idea what their talking about. Espeically if they open up a thread saying they've heard of a golden eagle head gasket leaking.
Besides that, who in their right mind would bore that much out of a b20 block anyway? Thats just asking for trouble.
Old Aug 23, 2007 | 07:10 AM
b20beast978's Avatar
i recall b20's bieng 84mm from the factory so why not buy an oem headgasket and play it safe? Anything over 84mm without sleeving is rather risky knowing the history of these sleeves!
Old Aug 23, 2007 | 07:24 AM
Default Re: (b20beast978)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b20beast978 &raquo;</TD></TR><TR><TD CLASS="quote">i recall b20's bieng 84mm from the factory so why not buy an oem headgasket and play it safe? Anything over 84mm without sleeving is rather risky knowing the history of these sleeves!</TD></TR></TABLE> why should he buy another gasket? he already has our vtec kit with a gasket that works and if you have read he is 85mm now not 84mm so he needs a 85mm gasket. as far as the boring a b20 to 85mm with out sleeving, i agree, i would not do it ether the sleeves are way to week
japanstar_ef9
Jun 11, 2008 08:26 AM
CW-ITR
10
Oct 5, 2007 11:43 AM
lilbithonda
Nov 13, 2005 12:10 PM
crx1856
Jul 21, 2003 03:27 PM
