b16a 1st gen wiring
Old Jun 11, 2002 | 04:39 PM
EF'n's Avatar
Default b16a 1st gen wiring
looking for suggestions on wiring for my 89 dx hatch that i am putting a b16a into. i have the stock dx harness and i have a 90 teg harness or i have the money to do a hasport harness. i asked on here if i could use the 90 teg harness and all i got was a "no" with no reason why. what are all you guys using or did you all pay someone to do your swap?
Old Jun 12, 2002 | 05:15 AM
badCRX's Avatar
New User
Default Re: b16a 1st gen wiring (revhardracing)
You want to use the stock wire harness to your car and modify it. If you look at your integra harness, most likely not all of the plugs will match up. Mainly I'm referring to the ones by the passenger shock tower where the interior and engine harnesses mate up and the ones by the driver's side firewall corner.
Old Jun 12, 2002 | 07:37 AM
Trey's Avatar
25 Year Member
Default Re: b16a 1st gen wiring (badCRX)
The DX harness is totally different than the HF and the SI since they used MPFI. The DX didn't.
This article is for the ZC but is basically the same for the B16a:
http://hybrid2.honda-perf.org/tech/4gdxtozc.html
I have ECU pinouts here:
http://www3.honda-perf.org/community...Trey/b16a1.htm
Good luck,
Old Jun 12, 2002 | 08:25 AM
brian.edge's Avatar
Default Re: b16a 1st gen wiring (Trey)
every thing you need to know is right here http://www.hasport.com just scroll down to 88-91 civic with a b16.....shows you all the wiring and they even carry a conversion harness for your car so you dont have to do the work....which helps out alot.....trust me
-oops forgot to put in the link....my bad
[Modified by lilhibbs, 5:26 PM 6/12/2002]
Old Jun 12, 2002 | 02:56 PM
EF'n's Avatar
i understand the dual point and multi point. my question is, can i put a teg harness on the b16a (i know i can) but will it plug into my dx car harness? i am too lazy to check for my self, plus i was hoping someone on here has done or tried to do this.
Old Jun 12, 2002 | 04:23 PM
Katman's Avatar
Lazyness -- the decay of all people.
even if a 90-91 integra harness does work on your DX, you still need to wire up the needed items from the ecu to passengerside shocktower main harness plugs.
There's no way out of rewiring your DX ya lazyass..hahaa..jfwy..
Old Jun 12, 2002 | 05:23 PM
EF'n's Avatar
Default Re: b16a 1st gen wiring (Katman)
i have done a couple of b16a swaps into 2nd gen tegs so i know that i have to run 4 wires i just wanted a short cut to the multi point wiring. i am no so much lazy but i have a 2 year old boy and he takes up most of my time so when i do work on my project i try to make it worth while.
Old Jun 12, 2002 | 06:40 PM
Katman's Avatar
heh, understood..
BiG_DeE
Jun 3, 2010 08:36 PM
CRseXxy
Jul 22, 2004 08:07 PM
JapJunkie
Apr 18, 2004 11:05 PM
rexheadb16a
May 30, 2003 03:10 PM
