uhh windows stopped moving up or down ?
Old Aug 6, 2007 | 10:59 AM
vivithemage's Avatar
Default uhh windows stopped moving up or down ?
94 civic LX window's decided to not go up or down now.
I started her up, put down the front left and front right window, I drive 2 miles, park and try to put them up and they no longer go up and the back two do not go up or down either.
The only one that works is the drivers side...what's the deal?!
924doorEG's Avatar
motor went out prolly
Old Aug 6, 2007 | 11:10 AM
Default Re: (924doorEG)
but why would my drivers side work?
where is the motor located?
Old Aug 6, 2007 | 11:18 AM
Banjo the Ninja's Avatar
Default Re: (vivithemage)
Each window has its own motor, you can see it when you pull off the door panel.
Old Aug 6, 2007 | 11:21 AM
Default Re: (Banjo the Ninja)
is it just a coincidence that they all crapped out at the same time? all except the edrivers side?
Old Aug 6, 2007 | 12:17 PM
so you are all saying i need 3 new motors at 100$ a pop ?
Old Aug 6, 2007 | 01:28 PM
Have you tried to raise and lower the motors from their own controls on the doors? Could just be a bad relay on the drivers door panel, or some loose wires. I wouldn't jumpt to replacing all of the motors just yet.
Old Aug 6, 2007 | 01:32 PM
cartune network's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Banjo the Ninja &raquo;</TD></TR><TR><TD CLASS="quote">Have you tried to raise and lower the motors from their own controls on the doors? Could just be a bad relay on the drivers door panel, or some loose wires. I wouldn't jumpt to replacing all of the motors just yet.</TD></TR></TABLE>
^^^^^i would give that a try. both front window motors and regulators went bad on my 97 accord lx and because they were going really slow and i kept using the drivers switch for um and holding the switch up or down i blew the switches out on the drivers door and that lil box of switches cost me 300 dollars from honda. i wanted to kill myself and this was last year and now my passenger front window is stuck all the way up and the driver side window moves incredibly slow. i hate honda window motors.
Import Prelude
Jun 20, 2007 03:44 PM
Metal Head
Sep 22, 2006 08:28 PM
spoon_r_951
Jul 18, 2006 05:52 PM
macsmurray
Apr 29, 2006 05:29 PM
JamesQ
May 25, 2005 02:34 PM
