Erratic Idle & Flat Acceleration
Old Aug 6, 2007 | 09:35 AM
alwaysared's Avatar
Default Erratic Idle & Flat Acceleration
Hey
Put a new header on my 90 Civic Hatch -
Now it seems to idle very erractically and sometimes when accelerating it seems to be very flat with no power at all, then other times it accelerates fine.
Never had any problems before the new header was put on.
When changing the header i had to move and rewire the Oxygen Sensor, could this be the problem?
There are no check engine lights or anything like that.
thanks for any help.
Old Aug 6, 2007 | 09:51 AM
89efDUSTY's Avatar
Default Re: Erratic Idle & Flat Acceleration (alwaysared)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alwaysared &raquo;</TD></TR><TR><TD CLASS="quote">
</TD></TR></TABLE> Did you rewire it correctly? 1 wire or four? what on board Diagnostics? all this will help to solve the problem.
But just in case, make sure "OBD1-2" you connected all the wires right. Also make sure where you connected "hopefully soldered" the wires the connection is good. O2 modifies the shortband via the information sent by voltage readings with your AFR. Gl
Old Aug 6, 2007 | 10:14 AM
alwaysared's Avatar
Default Re: Erratic Idle & Flat Acceleration (89efDUSTY)
I believe there were 2 wires from the Oxygen sensor.
EDIT - Sorry one wire from the Oxygen sensor, the ECU has one flashing red light.
Old Aug 6, 2007 | 10:31 AM
89efDUSTY's Avatar
OBD0 = Definately your o2 sensor, if the car was running prior then the sensor should be good...make sure you don't have a leak prior to it also do you have a adj. FPR, if so are you @ stock, also are you running retarded timing or anything for boost. Probably though just a bad connection @ the splice location.
Old Aug 6, 2007 | 10:50 AM
alwaysared's Avatar
Yes its OBD0, car is stock std 4 speed civic, no FPR, no boost or anything like that.
Everything seems to be connected ok.
Should i start over and rewire the Oxygen sensor again? or do i need to get a new sensor?
Old Aug 6, 2007 | 11:27 AM
89efDUSTY's Avatar
Sensor should be fine if all you did was pull the sensor and extend "one wire" the wire. Check the voltage of the o2 when the car is @ idle with a multimeter.
Old Aug 6, 2007 | 12:44 PM
alwaysared's Avatar
Ok, checked the voltage , at idle it was 0.39
Not sure if i did it right or not?
Granulatedsugar
Apr 15, 2016 01:19 PM
vtec6200
14
Jun 18, 2009 03:08 PM
alupso
Mar 4, 2008 02:43 AM
showlude93
Dec 2, 2006 09:34 AM
Spudddy
May 4, 2003 12:00 PM
