RSX foglights(besides OEM)
ebay ones fit cool. there is a tiny gap. but its about only 1cm..i'd rather get ebay ones b/c rox on the freeway crack the glass anyway and if u got oem there goes your oem($200) housings...so get some clear vinyl while your at it..some thick vinyl is a must..esp. if you drive freeway alot.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dcsleeper408 »</TD></TR><TR><TD CLASS="quote">ebay ones fit cool. there is a tiny gap. but its about only 1cm..i'd rather get ebay ones b/c rox on the freeway crack the glass anyway and if u got oem there goes your oem($200) housings...so get some clear vinyl while your at it..some thick vinyl is a must..esp. if you drive freeway alot.</TD></TR></TABLE>
thanks for the info..what seller did you use?
motorblvd (seller) is best. and ebay are way better than OEM, the harness is even better. granted there are 3 different harnesses i've seen out there with the ebay kits, the motorblvd is the easiest one to install.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NTCustoms »</TD></TR><TR><TD CLASS="quote"> and ebay are way better than OEM, the harness is even better. </TD></TR></TABLE>
How are you basing this opinion? The OEM fogs fit great, plug in like they should and are of decent quality. The only drawback is the lens cracking, but mine have not yet done this and the ebay fogs are just as likey to have this happen.
i am basing my opinion on other people's opinions. many people i know don't like the fact that the OEM fogs will only turn on with the headlights. the ebay kits allow the fogs to be turned on with the parking lights only. also, the OEM fogs will not turn on when you activate high beams. the ebay fogs allow you to do this also. yes OEM fits great, but so do the ebay kits.
ebay fogs r fine. worked/fitted perfect for me. i came across an oem set on ebay for 150 so i couldnt pass those up. and sad to say yes one side already cracked. so ebay is just fine.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NTCustoms »</TD></TR><TR><TD CLASS="quote">i am basing my opinion on other people's opinions. many people i know don't like the fact that the OEM fogs will only turn on with the headlights. the ebay kits allow the fogs to be turned on with the parking lights only. also, the OEM fogs will not turn on when you activate high beams. the ebay fogs allow you to do this also. yes OEM fits great, but so do the ebay kits. </TD></TR></TABLE>
Having the OEM fogs turn on with parking lights is an easy and documented fix. Also, note that it is illegal to run foglights with your high-beams on.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Todd00 »</TD></TR><TR><TD CLASS="quote">
thats a state regulation that only pertains to your state.
It's not illegal in NC..how do I know? i just asked a State Trooper
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DC5s0uth »</TD></TR><TR><TD CLASS="quote">ebay fogs r fine. worked/fitted perfect for me. i came across an oem set on ebay for 150 so i couldnt pass those up. and sad to say yes one side already cracked. so ebay is just fine. </TD></TR></TABLE>
which ebay ones/brand/seller did you use?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NTCustoms »</TD></TR><TR><TD CLASS="quote">motorblvd is a very legit ebay seller. i would recommend him over anyone else.</TD></TR></TABLE>
yeah i looked at his store and he didnt have any oem looking fog lights for the RSX..but i just found a set and am currently bidding
what the hell, why?
what the hell, why?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thrty8street »</TD></TR><TR><TD CLASS="quote">
what the hell, why?</TD></TR></TABLE>
Because it is in some states. This is why OEMs turn off when the high-beams are switched on.
Why does one need foglights when the high beams are switched on anyways? The entire idea of 'foglights' are that they aid when driving in the fog; therefore, they should be aimed and positioned accordingly.
This mod is equivalent to the 'fast turn signal' mod. Serves no purpose.
This mod is equivalent to the 'fast turn signal' mod. Serves no purpose. </TD></TR></TABLE>
ok its in some states.... but WHY?????
So, just because something is not needed, it automatically becomes illegal? Thats just stupid. I dont think anyone needs a lecture on lighting positions. I just want to know why its illegal.
I dont see a reasonable or logical explanation to why it should be illegal. Having your fogs while your high beams is not going to hurt anyone. If your high beams are on, then there should be no oncoming traffic anyway.
I just dont understand the law's logic.
vietshinobi
Oct 22, 2006 06:36 PM
bonta-kun
Jul 25, 2004 10:13 AM
