ES motor mount inserts in a DD
Old Aug 5, 2007 | 08:00 PM
LukieLuc's Avatar
Default ES motor mount inserts in a DD
I have a 95 honda prelude si with a jdm h22a with I/H/E/FW/Clutch upgrades. I am planing on putting in Es motor mount inserts. Right now my car doesn't vibrate at all not at idle or when moving, i wanted to know will the car start vibrating Allot or just a little bit and if i have a daily driver is it really worth the less comfort?
Old Aug 5, 2007 | 08:02 PM
mgags7's Avatar
it won't be a big difference, though the time spent on installing those bastards is going to suck.
The good thing is they're cheap.
Old Aug 5, 2007 | 08:12 PM
saikou's Avatar
Most of the vibration will be a result from the inserts in the rear mount. I have the explicit speed performance motor mounts and thought my motor was moving excessively without the front mount. So, I bolted the front motor mount with ES inserts and the vibration was not changed. Anyways, ended up being bad axles.
85_305
Honda Civic (2001 - 2005)
19
Jul 28, 2009 02:14 PM
DeeCeeTwo
Jul 19, 2005 11:32 PM
TeGGY_LS
Nov 30, 2004 01:05 PM
Ri5e
Dec 26, 2001 04:29 PM
