HELP!!!!! B18 SPUTTERING
ALRIGHT GUYS, I INSTALLED MY B18
HAD SOME PROBLEMS WITH THE WIRING AFETER GETTING IT BACK FROM HASPORT, SO I TOOK IT DOWN TO GET IT RE-WIRED AT REDLINE IN DALLAS, IT WAS THROWING THE IGNITOR CODE (16) SO I SWITCHED IT OUT BUT NOW WHEN I DRIVE IT IT SMOKES PRETTY BAD AND WHEN IT HITS 3GRAND IT STARTS KIND OF JERKING (ITS HARD TO DESCRIBE) ITS LIKE IT TURNS RETARDED AT 3GRAND UNLESS I STAND ON THE GAS. WHEN I PUNCH IT ITS FINE BUT IF I DRIVE IT NORMAL IT DOES THIS SPUTTERING... I HAVE NO IDEA WHAT IT IS, PLEASE HELP.
i had that problem with mine,except mine didnt throw any codes, i had to clean out the little screens in the injectors, and i went ahead and replaced the fuel filter and it was fine after that
thanks to all you guys who responded i apparently was looking at the wrong code, i did have the problem with the number three injector not pulsing i think it may be a lead... i will check it out tomorrow and upd
ate the situation, thanks again for all your help..
