Wiring Harness - fix or kick
I got ahold of a 91 crx si shell only and had to throw an engine in it fast as other car is about to go. All I had was an 1.5 engine with tranny and engine wiring harness... from a 90' 4-dr. However of course the engine wiring harness doesn't fit the plug on the drivers side before it goes through the firewall. It plugs in everywhere else and I was hoping to make it easy and figure out what wires I need to plug from the original to my stock si plug? My Haynes manual doesn't help much. Thanks
That conversion would still affect it on the other side of the harness (drivers side)? I do have the DPFI harness, ecu, and parts. I had hoped it was just the difference from the civics harness to the crx's. If I were to grab a harness from a crx with the 1.5 engine, you are saying I would still have this problem, and have to try and convert? Everything is put together and this is my only problem before I am rolling.
B2FiNiTY
17
Feb 25, 2004 03:22 PM
