h22A 85 CIVIC PROJECT
Old Aug 5, 2007 | 02:07 PM
importwarriorsi's Avatar
Default h22A 85 CIVIC PROJECT
I have an 85 civic hatch black with many usable parts the motor throwed a rod and knocked a dime size hole in the block now its of no use to me and I dont really want to fix it.There has been a ton of stuff added to the car but like I say the engine is shot.This would make a great project if you have an H22a to drop in it.That is all you would need.Car has been completly striped the only thing it has in it is the dash and such.No heat no ac.This thing is ment for the track.But a few runs on the street is fun well was lol.I hate to get rid off it but I need my carport and dont have the money to do anything to it to fix it
Items are as follows .A jdm h22a prelude vtec motor spoon chipped p28 ecu complete obd1 civic wire harness with cluster direct port headers apexi muffler under the drivers seat.A set of ground control coil overs.Yellow koni shocks.Custom axels stage 5 clutch masters clutch welded diff for full time posi.BDL68mm throttle body walbro 342 fuel pump fuel pressure regulator with gauge.Also unorthodox racing pulleys custom motor mounts custom front traction bars.There is also a 70 hp shot of nos 4 fogger no bottle for it. I never had one for it when I bought it.A decent black racing seat also goes with it. I have a new extra custom axle that goes with it .I had 2 made for it and cost me 350.00 for the custom axles but now they wont cost you but 50.00 bucks.The guy that did them said I wont break these.Ill give you his card so you can call him if you ever do break them.I have other axle parts to go with it as well.The car will not turn over at all locked up due to lifters snaping in motor.I did this in sher stupidity by reving at really high rpms and high speeds a few times.I got to excited I guess.The parts on this car you can parts out yourself or use for your aplications. This car was very fast and did 12s at the track without spray.I never sprayed it but the old owner im sure did.This may have help with the motor screwing up.I am asking 1000 or best offer.Part this car out and make some dough on it or keep it.This is a deal being it took at least 6 grand to get this car where it was.Any reasonable offer I will cosider.You will need to tow car to your home.Location North Carolina
Modified by importwarriorsi at 12:22 AM 8/6/2007
Old Aug 5, 2007 | 06:59 PM
Default Re: h22A 85 CIVIC PROJECT (importwarriorsi)
Make me an offer
Old Aug 10, 2007 | 10:41 AM
dpine's Avatar
bump for an interesting swap. Did you make the mounts yourself? what is the condiftion of the title of the car? Any track times? where in NC are you located?
PM me
Old Aug 10, 2007 | 12:44 PM
Si2See's Avatar
pmed
Old Aug 11, 2007 | 01:24 PM
jweeks's Avatar
Default Re: (Si2See)
interest in any trades?
Old Aug 11, 2007 | 02:29 PM
UltRaH22's Avatar
pm'd
TypeRKoncepts
Nov 12, 2005 04:03 AM
TypeRKoncepts
Oct 2, 2005 07:50 PM
hatchbiatch
Apr 18, 2005 08:13 PM
shivic
Oct 18, 2002 12:18 PM
