~~sily 15x8?~~
yup your right mm..93 civic and some adjustables
I would like to know more then anything if stretching a drag radial is a bad idea compared to stretching a street tire.
I dont know what tires are used to drift. maybe that would help :x
Go by the manufacturer's specs. Tire manufacturers test their tires and specify a range of approved rim widths for them. If the rim is wider than the approved rim width, don't use it (especially for a drag radial).
What kind (make/model) of tire is it? (I looked up the BFG and the Nitto NT555R and didn't see that size listed.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by butter99 »</TD></TR><TR><TD CLASS="quote"> yup your right mm..93 civic and some adjustables
I dont know what tires are used to drift. maybe that would help :x</TD></TR></TABLE>
You want drift tires on a FWD platform? Did I get that right?
Anyways, drag radials are extremely soft compound tires, and drifting tires are extremely hard compound tires.
~~ FF driffttyy weeee no ahhah~~ya tire specs is a good thing to remember~http://www.wheelsnext.com/defa...tires
^^this is what 15x8 civics roll on >>nexin n3000<<^^>>
you think the stretched tires used to drift are approved?
Nexen tires?
Nexen tires?
Those aren't drag radials.
The Proxes T1-R is approved by Toyo for mounting on rims 6.0-7.5 inches wide. So no, I would not mount them on 15x8 rims.
And I wouldn't mount those crappy Nexen tires on ANY rims. Ever.
Let me guess - you bought 15x8 rims without having any idea what kind of tires would fit on them, or whether tires that fit on them would be a good size for your car. Am I close?
prety close mr tire man
>< many civic 15x8 roll with the unapproved proxes..
can somebody answer the drift question..?
are there approved stretched tires ? 195//
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by toyomatt84 »</TD></TR><TR><TD CLASS="quote">
Nexen tires?
yeah..nexan tires wont stretch..get tires that already have some sort of a stretched look to them..like falken ziex (crappy tires also but will stretch a bit) i don't recommend this setup for everyday driving but if you must do it then yes, it will work on 15x8 +25 offset, rolled fenders and maybe slight camber w/ teh perfect ride height will do the trick....but wont feel too good while riding all over the bumpy roads and potholes.
Nexen tires?
</TD></TR></TABLE>yeah..nexan tires wont stretch..get tires that already have some sort of a stretched look to them..like falken ziex (crappy tires also but will stretch a bit) i don't recommend this setup for everyday driving but if you must do it then yes, it will work on 15x8 +25 offset, rolled fenders and maybe slight camber w/ teh perfect ride height will do the trick....but wont feel too good while riding all over the bumpy roads and potholes.
pepperinyoureye
Dec 13, 2006 01:33 PM
Quad-Damage
Apr 17, 2006 03:27 PM
