exploring options for larger DIY t-bodies.
Old Aug 5, 2007 | 11:47 AM
thehatchninja's Avatar
Default exploring options for larger DIY t-bodies.
I'm in the research stages of my F2D build. Initially looking to do a mostly stock F22A6 i/h/e, cam, cam gear, milled head, tuning. However I eventually want to build something crazy with ITB's. Since the largest motorcycle ITB's I've seen are 42mm, and twm makes 50mm for the K's I've been looking for something larger for my 2.2L build. So i've just been poking around to see what I could find.
Some kit....not sure what motor this is for. http://www.extrudabody.biz/ser...etail
Single ITB....45mm $99
Modified by thehatchninja at 4:10 PM 8/5/2007
Old Aug 5, 2007 | 11:55 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">Extrudabody ITBs are different. The difference is simple, elegant, and better for many applications and custom installation.
In a nutshell, instead of making an ITB that is made to fit a particular application, we make a Universal ITB. Our competitors either cast their ITBs or CNC them specific to an application and manifold mounting requirements. Instead, Extrudabody starts with, guess what, an extrusion. The extrusion is then machined to match up to all the ITB hardware - throttle shaft, plate, fuel injector, etc. Our ITB then connects to one of our Base Plates that adapt the universal ITB design to a bolt pattern specific to your intake manifold. To the right is an assembled ITB on top of a Weber-style Base Plate that could replace a DCOE carburetor.
You can also make your own custom base plate from plate aluminum. Now you probably understand why our design is so versatile. Instead of changing the whole ITB design for each and every application, we just change the much simpler Base Plates. This saves us money, saves you money, and means that you custom guys out there can make your own base plate with a band saw and a drill press.</TD></TR></TABLE>
Old Aug 5, 2007 | 12:02 PM
oh....well it should be easy for b-series guys.
Old Aug 5, 2007 | 05:42 PM
91sihatch's Avatar
Default Re: (thehatchninja)
Ducati makes a 50 or 52mm throttle body. I can't remember the exact size but its up there.
Although this seems like a good alternative. Too bad they don't make anything bigger.
Old Aug 5, 2007 | 08:06 PM
wed3k's Avatar
im using the GSXr1000 TB's. i believe they taper from a 52mm to 45...
i also have the same setup, this is being designed for 8500rpm
Old Aug 5, 2007 | 10:17 PM
98vtec's Avatar
moderator emeritus
Default Re: (wed3k)
hayabusa throttles are 46mm at the throttle plates.
Old Aug 7, 2007 | 04:16 PM
this company actually makes a 50mm too.
Old Aug 7, 2007 | 05:28 PM
machine4321's Avatar
hey those are really nice , good find man
Old Aug 7, 2007 | 05:33 PM
in fact , you could make a really nice set for less then twm and a tad more then a properly done diy
Old Aug 7, 2007 | 07:22 PM
thanks... Google does wonders I thought they were a good possible alternative to motorcycle ITB's.
The only disadvantage is that the motorcycle ITB's will come with sensors, injectors etc that may come in handy.
Old Aug 7, 2007 | 08:47 PM
all_motor_mike's Avatar
i have a neon and i cut up and used stock neon throttle bodies, bolted them to a common backing plate and welded and bolted it all together. i have the advantage of running my stock tps doing it this way too. heres a vid i just did today along with one of the pics i took......
http://s125.photobucket.com/al...1.flv
Old Aug 8, 2007 | 02:49 AM
d15Beta's Avatar
could try fabbing up 4throttles, from the d-series.. lol i think theyre around 55mm
4 of them sounds nice.. lol
Old Aug 8, 2007 | 02:03 PM
Default Re: (all_motor_mike)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by all_motor_mike &raquo;</TD></TR><TR><TD CLASS="quote">
what else is done to that thing?
Old Aug 8, 2007 | 02:41 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thehatchninja &raquo;</TD></TR><TR><TD CLASS="quote">
what else is done to that thing?</TD></TR></TABLE>
not to much......... its a freshly rebuilt engine (all oem stuff), i did some mild porting, crane #14 cam, mopar computer, and the itb's. they are for my race car BTW, the pics i took of it are on my daily driver though.
Old Aug 8, 2007 | 03:32 PM
cool.
Old Aug 8, 2007 | 05:09 PM
ahh man thats what i wanted to do , with the neons . dang nice job though
vtecnician-eg6
Aug 27, 2009 08:38 AM
jay di em02
Jul 29, 2008 03:50 PM
kornmanz
Nov 28, 2007 08:09 AM
.Unknown.
27
May 28, 2005 05:29 PM
Zero2Sixty
Apr 7, 2003 06:02 AM
