ahhh wont start
got a 97 accord auto 2.2 cyl 280,000.. i jus changed my radiator ,had a really half dead battery also. changed roter and coil was said to be okay, plugs good. used to hav check engine most days it came and went . now she wont start after coming out da store she didnt want to crank i noticed after i changed my radiator my ac wouldnt blo cold dont kno why ? but now she wont turn over ? she cranks and tryies but wont go check engin light wont throw me a code ! i been all thrw this page i cant even get her to my mechanic im in west buble expletive. i noticed the hose at the bottom of my radiator was kinda twisted which may hav explained my ac issue .my engine temp never moved past 1below mid level so im sure she aint overheat .... help new battery ,fuel pump kickin in and new fuel filter and 5,00 left on the books to pay,,
Nappyred187@hotmail.com
Check to see that your ECU is grounded, the ECU ground is located either on the thermostat housing or engine block near the thermostat housing.
Check this link out, under ECU and Ignition Problems:
http://techauto.bravehost.com/
The flowchart is very good.
but u see the car started several time and ran well after i changed my radiator. i will again go check on those ground. can i take my ecu and main relay to like autozone or somplace to be checked ?
Ace of Spades
Nov 1, 2004 06:25 AM
