Home made ITB's For H22A
Hi,
I would made an individual throttle bodies for my H22A BB4 prelude.
Someone have itb's on h22 ?
I think use 929 cbr 42mm throttle bodies or gixxer tb's...which is better ?
Thank's
Thank's
use hayabusa throttles. 46mm throttle plates and they are able to be spaced out so you can align them with the intake ports.
other gixxer's throttles are too small, imo
Ok thanks' 98Vtec, I see your setup it's good man !
what'is the most expensive in homemade Itb's ?
Sorry for my english, I'm french ! lol
my setup didnt work out due to me allowing the welder to do some work that i should have never sent to him in the first place. Would have been a great setup if the throttle wouldnt have gotten warped and the throttle linkage springs would have held together better.
I spent alot of money on that setup. The velocity stacks were like 200 dollars if i remember correctly. I'm still wanting to do another set so i can redeem myself.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dagle »</TD></TR><TR><TD CLASS="quote">aww u should swap that. from FDM to USDM.</TD></TR></TABLE>
It's a Jdm Prelude.
So, if i buy a gixxer 1000 or busa tb's and the velocity stack, what remains me it found?
The h22a injectors fit on tb's ?
Thx
It's a Jdm Prelude.
Thx
you have a few choices here:
A) you can cut up a stock IM to get use the flange and injector ports, then have runners welded on.
B) you can purchase a CNC'd flange and have runners welded onto the flange
There is alot of work involved in getting these working. Researching this material and less posting is going to net greater results because i am sure not going to go through everything you need to do when everything has already been layed out for you in previous threads.
