Where is this oil comig from?
Old Aug 4, 2007 | 03:50 PM
djtsmith007's Avatar
Default Where is this oil comig from?
This thread https://honda-tech.com/zerothread/2061489
Has coolant leaking where i have oil spotting up...exact same spot. And its not alot just drops a day. These pics are from my car...BTW...97LS/Vtec with b16a2 head. I cleaned it up a lil so its better to see.
Old Aug 4, 2007 | 03:55 PM
DC2R_JOE's Avatar
Default Re: Where is this oil comig from? (djtsmith007)
well you have a ls/vtec.. Its very common to have a blown head gasket with that set up!
Old Aug 4, 2007 | 03:57 PM
Default Re: Where is this oil comig from? (DC2R_JOE)
U sure? i had a compression check done and came back 175 across all 4.
Old Aug 4, 2007 | 04:15 PM
redDAinteg's Avatar
175 across is good that its all even, but its pretty low as compared to what it could/should be.
Old Aug 4, 2007 | 04:23 PM
Default Re: Where is this oil comig from? (redDAinteg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redDAinteg &raquo;</TD></TR><TR><TD CLASS="quote">175 across is good that its all even, but its pretty low as compared to what it could/should be. </TD></TR></TABLE>
what should it be 190's?
Old Aug 4, 2007 | 05:09 PM
Tenacious T's Avatar
Its doesnt matter. The gasket may be blown around the coolant ports, but may still be sealing around the cylinders.
Old Aug 5, 2007 | 10:08 AM
redDAinteg's Avatar
Default Re: Where is this oil comig from? (Tenacious T)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by djtsmith007 &raquo;</TD></TR><TR><TD CLASS="quote">
what should it be 190's?</TD></TR></TABLE>
Just for example, I have a b18c and when I did my compression check I got 220 215 208 220. In the helms manuel, it says 280 is the max and I believe 120 is the minimum.
Old Aug 5, 2007 | 10:44 AM
kchungb17a's Avatar
It is very common for LS/VTECs to leak oil and or coolant at that corner of the engine. And yes you can still have good compression despite this leak as it does not effect cylinder sealing. Of course it could just be a bad hose somewhere. DO A COOLANT PRESSURE TEST. This is the sure fire way to find out where it is coming from. If you can't get a hold of one, a shop should do it for about 1 hour's worth a labor. It's a total rip, but at least you'll know.
Old Aug 5, 2007 | 12:16 PM
EARLdaSQUIRREL's Avatar
official honda whore
Default Re: Where is this oil comig from? (kchungb17a)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kchungb17a &raquo;</TD></TR><TR><TD CLASS="quote">It is very common for LS/VTECs to leak oil and or coolant at that corner of the engine. And yes you can still have good compression despite this leak as it does not effect cylinder sealing. Of course it could just be a bad hose somewhere. DO A COOLANT PRESSURE TEST. This is the sure fire way to find out where it is coming from. If you can't get a hold of one, a shop should do it for about 1 hour's worth a labor. It's a total rip, but at least you'll know. </TD></TR></TABLE>
you can also rent a tester from most local auto parts stores...
madjdmek9
May 14, 2008 10:19 AM
b20integrapower
Jan 23, 2006 06:12 PM
baboonstyle
18
Nov 11, 2005 04:02 PM
itr1235
Oct 12, 2004 10:56 PM
vtec.dc2
Aug 15, 2003 06:33 PM
