CEL Blinking while driving now my car sounds like a SUBARU?
OK so i am driving to my dads house to go wash my car and also reconect my secondary O2 because i just put on a new header and got my exhaust done.as i am driving i noticed the CEL starts blinking , then the car starts to feel slugish and sounds like its runing on 2 cylinders. keep in mind that the CEL was alredy on because the secondary O2 was not pluged in.
Any ideas on whats wrong with my car
you might want to check your spark plugs too. someone had the same problem and they also compared it to sounding like a subaru wrx. they sad when they checked it, that it was just a bad spark plug.
checked plugwires all look good and on tight, dizzy looks ok no moisture.
i will have to wait to check spark plugs until i get a deep socket. I also drove with the secondary o2 unpluged for three days no problem,
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FUPAH8TR »</TD></TR><TR><TD CLASS="quote">So i jumed it and this is what i got
74 random misfire cylinder 4
</TD></TR></TABLE>there you go, a problem in cylinder 4, check ur plugs wires and maybe dizzy/ cap and rotor, if all is good then its ur head gasket
I've seen some seriously WARPED heads causing coolant consumption and thusly misfires, but there was no real smoke to speak of. at least nowhere near what you'd expect for a blown headgasket.
ok i am waiting to get a ride to the auto parts store so i can buy new spark plugs and get a deep socket to take them out i hope its just a bad plug
Secondary O2 only monitors the cat, it has nothing to do with the engine misfiring.
Since you have a misfire code for cylinder 4, make sure you check every part of the circuit inline with that cylinder, starting with the contact points in the cap, to the plug wire connection at the cap. Perform a resistance check of the number 4 wire, and see if its shot. 25K (25,000 Ohms) indicates a shot wire @ 70 degrees. Check the plug hole ,and make sure no fluids got down there. Then check the plug itself, and make sure gap is correct, and the plug is not broken.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slowcivic2k »</TD></TR><TR><TD CLASS="quote">Secondary O2 only monitors the cat, it has nothing to do with the engine misfiring.
Since you have a misfire code for cylinder 4, make sure you check every part of the circuit inline with that cylinder, starting with the contact points in the cap, to the plug wire connection at the cap. Perform a resistance check of the number 4 wire, and see if its shot. 25K (25,000 Ohms) indicates a shot wire @ 70 degrees. Check the plug hole ,and make sure no fluids got down there. Then check the plug itself, and make sure gap is correct, and the plug is not broken.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FUPAH8TR »</TD></TR><TR><TD CLASS="quote">if it is my head gasket wouldn't be smoking like a champ</TD></TR></TABLE>Na, there are some case's where there wont be smoke but the head gasket it blown.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by duheeat »</TD></TR><TR><TD CLASS="quote">Na, there are some case's where there wont be smoke but the head gasket it blown.</TD></TR></TABLE>
x2
There are times where exhaust will be forced into the coolant due to compression, as well as air/fuel, but not enough pressure in the cooling system to force coolant in the chamber.
x2
