6 Sigma 1/4 Sports two-point-three Liter Street All Motor HB part II
Well we finally did some real track testing on Friday night with the motor in the new EG hatch. We messed with some slick sizes and tire pressures and finally found the right combination. We broke a couple parts in the process but it was all worth it. I have attaches some pics of the timeslips. Hopefully they are easy to view.
Here is the 11.79 timeslip
Some More Broken Axles... 187ft/lbs does this kinda stuff
**Street car trim**
*Full Glass, carpet, radio, speakers, etc....
*F23 crank
*F23 Rods
*H22 pistons
*Stock Unported Head
* Blox stage II cams and valvetrain
*Euro R manifold
*STR 70mm TB
*Stock Valves
*Stock B16 tranny open diff
*Stock Axles (Ok but we have stock in those axles haha)
*Tuned with Crome
*91 Pump
**Street car trim**
*F23 crank
*F23 Rods
*H22 pistons
*Euro R manifold
*STR 70mm TB
*Stock Valves
*Tuned with Crome
*91 Pump
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alterdcreations »</TD></TR><TR><TD CLASS="quote">what bearing clearances did you use with the acl bearings?
what on the mains and the rods if you dont mind to share?</TD></TR></TABLE>
Mains and rods were around .0015. Honestly we really were not being that precise as we normally would be with a race engine. We basically wanted to see if this motor would just run. We even reused the piston rings. (Yes I do not condone that...)
If all goes well during the week we'll probably get some more testing done before BOTI up in sac this weekend. Next testing will be swapping out the Euro R manifold and try out
the Skunk 2 manifold and hopefully we'll get the Skunk pro 3's on time as well...
and also alignment is a big deal going down the track because I was fighting the wheels
bad.....
Btw.. tires size were M&H 23's
bad.....
11.79 with open diff,oem budget build= Dayum!! How much does the EG weigh without driver? Are the H22 pistons USDM 10.1, JDM 10.6, or Type S 11.1?? How much did the pistons have to be shaved???
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AllMtrRex »</TD></TR><TR><TD CLASS="quote"> How much does the EG weigh without driver? </TD></TR></TABLE>
We did happen to also weight it Friday night... 2050lbs. w/o driver. This combo is a champ.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM JEFFREY »</TD></TR><TR><TD CLASS="quote">wow 11's with oem bottem end.
Thanks for the support guys. I have no problem putting it on the dyno and beating the crap outta this motor to do some testing
**News flash** While I was writing this reply.. I just got word that we will be adding these new parts for the next race.
Scheduled for next weekends race:
*Alignment
*Ported Head
*Flat High comp valves
*ITBs
*New tune
Modified by SixSigmaRaceEngineering at 11:12 AM 8/6/2007
*Alignment
*Ported Head
*ITBs
*New tune
