After done swap from D to b16a
the gas pedal cable connects to throttle body is kind short.
so what should i do and also the throttle body cable bracket wont fit
onto to b16a intake manifold..
need advise please
and is throttle body cable easy to swap
how to ?
thanks
Modified by crazyguy at 2:12 PM 8/4/2007
need advise please
how to ?
thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crazyguy »</TD></TR><TR><TD CLASS="quote">the gas pedal cable connects to throttle body is kind short.
need advise please</TD></TR></TABLE>
Um... What?
From what I can understand your using the D series throttle cable. Go get a B series throttle cable.
Um... What?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crazyguy »</TD></TR><TR><TD CLASS="quote">so u are saying i need to swap the throttle body cable too?
oh man.</TD></TR></TABLE>
yes
yes
It's actually very easy to swap, nothing to it. Just get in at where the pedal is and detach it from the pedal and pull it through the firewall from the inside you twist and turna and then put the b series cable in its place and your done.
BryanM.
Jan 10, 2022 04:16 PM
crazyguy
Aug 6, 2007 05:45 AM
