Cooling Fans
Old Aug 4, 2007 | 12:07 PM
EsaHonda's Avatar
Default Cooling Fans
Hi Everyone. I'm new to this forum. I have a 1998 Honda Accord LX stock 4-cylinder. After being brought to the shop, I was told the cooling fans are inoperable due to lack of ground from pcm. They recommended that I have this repaired before winter gets here. They informed me it would run me a little over $750.00 to fix it. The weird thing is that I see the fans do come on and off and my car is not overheating at all. Are they trying to scam me or what should I do?
Old Aug 4, 2007 | 02:35 PM
hondadude's Avatar
Default Re: Cooling Fans (EsaHonda)
If you can open the hood and let the engine idle with A/C off, and the engine gets up to temp and the fans cycle and keep the temp steady.
I wouldn't be worried at all
Old Aug 4, 2007 | 05:12 PM
BluLude's Avatar
if it doesnt overheat they might be BS'ing you, if the fans operate normally then the car has no issue...I would bring it to someone else just to double check because whatever they are saying makes no sense. Did you bring the car in telling them there was a problem or was it during some service where they told you there was an issue?
Old Aug 4, 2007 | 07:36 PM
361 accord's Avatar
Default Re: Cooling Fans (BluLude)
sounds like theyre trying to poke youre eyes
on them
Old Aug 4, 2007 | 07:45 PM
02 accord's Avatar
Default Re: Cooling Fans (361 accord)
Here's a better one.
Old Aug 5, 2007 | 08:38 AM
EsaHonda's Avatar
Default Re: Cooling Fans (hondadude)
The day when i got the car out of the shop drove it home it was a hot day, i let the car idle with the A/C off but the cooling fans were working normal. Just like you said, i never had a problem similar to this with any of my cars, so i'm going to keep my hears on the cooling fans to come on and off and my eyes on the temp gauge just in case. Thanks a lot for the replys.
LMPitts
Feb 20, 2014 10:41 AM
RAYThOM
Classic Hondas
Jun 16, 2008 10:33 AM
williamsmh
Sep 4, 2005 10:20 AM
JDM-EJ1
Jan 1, 2005 08:12 AM
magnet05
Aug 9, 2004 06:48 PM
