I am idling really hi ...good/bad?
Old Aug 4, 2007 | 09:15 AM
jordan_civic's Avatar
Default I am idling really hi ...good/bad?
Yesterday I took of the the filter box cover so that it would be like a short ram. Then I started it up and it was idling at like 1 1/2 or 3/4...
Is it alright if i take the filter box cover off and should i be worried about the idling hi or is it normal...or what?
Any info is helpful...Thanks
Old Aug 4, 2007 | 09:39 AM
Default Re: I am idling really hi ...good/bad? (jordan_civic)
hello?
Old Aug 4, 2007 | 09:41 AM
94 IntegraLS's Avatar
My car idles high while it warms up but you car should idle at about 7-800 RPM's... any higher than that you should adjust your idle... but if it idled fine before you took the intake cover off then id put it back on and just buy an intake.
Old Aug 4, 2007 | 09:50 AM
JThrasher79's Avatar
Default Re: I am idling really hi ...good/bad? (94 IntegraLS)
opening your intake box should have no effect on your idle, 7-800 is where you should be at when warm.
Old Aug 4, 2007 | 02:01 PM
Default Re: I am idling really hi ...good/bad? (JThrasher79)
Ok...I took off the intake cover off again. Then I discover that the last owner had put in a K&N Filter. So I dont have to buy a filter now. And I went driving and went on the highway and now its so much better throttle response and somewhat acceleration. Now when I get up to Vtec and the 5800 openers it just roars. I think i will leave it off for good now. With a short ram be just as good and better than stock with k&n or what? I dont really wanna get a cold air intake. It tends to rain alot here.
Old Aug 4, 2007 | 04:04 PM
DC2R_JOE's Avatar
get a intake! its a much better sound and will look much nicer
david420
17
Aug 14, 2012 06:23 AM
namewasdallas
May 12, 2010 02:36 PM
meheartmycivic
Jun 4, 2009 03:45 PM
done
Nov 1, 2002 09:11 AM
