KYB GR2's wont fir 93 eg??
Old Aug 4, 2007 | 09:05 AM
trecool44's Avatar
Default KYB GR2's wont fir 93 eg??
Hello, I attempted to put GR2's on my friend's 93 dx hatch today and the shock bodies are too big to fit into the forks at the pinch point. Has anyone else had this problem, yes the shocks are the right part #.
Old Aug 4, 2007 | 09:07 AM
ma_rio44's Avatar
Default Re: KYB GR2's wont fir 93 eg?? (trecool44)
with a screw driver you need to open the forks a lil bit more. and they will fit. they just tighten them up with the screw. they will fit
Old Aug 4, 2007 | 09:09 AM
trecool44's Avatar
I heated them up and spread them open alot, they still dont make it over the bottom weld, and then they are tapered out above that.
Old Aug 4, 2007 | 12:35 PM
trecool44's Avatar
bump
Old Aug 4, 2007 | 05:25 PM
elmo908's Avatar
I have gr2s on my 93 vx hatch, works just fine.
Old Aug 4, 2007 | 07:01 PM
f22beast's Avatar
Default Re: (elmo908)
My car is the one trecool44 was working on. We tried everything but boring out the fork. We torched it and opened it still not even close. We measured the hole in the fork and got 1.492" and the dia of the shock is 1.642". Two tenths of an inch is quite an interfeirence fit.
Old Aug 5, 2007 | 04:26 AM
f22beast's Avatar
Default Re: (f22beast)
bump
Old Aug 6, 2007 | 03:34 AM
f22beast's Avatar
Last Bump
Old Aug 6, 2007 | 03:58 AM
JSPECSIR's Avatar
i have gr2 on my 94 hatch, no problems.
Old Aug 6, 2007 | 05:03 AM
f22beast's Avatar
Default Re: (JSPECSIR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JSPECSIR &raquo;</TD></TR><TR><TD CLASS="quote">i have gr2 on my 94 hatch, no problems.</TD></TR></TABLE>
Did you install them
Old Aug 6, 2007 | 05:33 AM
f22beast's Avatar
Can someone varify the measurements i stated above.
Old Aug 6, 2007 | 09:02 AM
f22beast's Avatar
OK i called KYB and they said that the max diameter on the shock body is 1.640".
Does anybody know what the i.d. of the hole in the fork is or where i can find specs on it. I think someone may have changed some parts on this suspension b4 i bought the car. (93 Civic DX Hatch)
Old Aug 6, 2007 | 03:15 PM
JSPECSIR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by f22beast &raquo;</TD></TR><TR><TD CLASS="quote">
Did you install them </TD></TR></TABLE>yep , they went right on. no problems.
Old Aug 7, 2007 | 03:39 AM
f22beast's Avatar
Last night I tryed the other side and the fork was the wright size i think the guy i bought it from blew both shocks and threw an integra shock and fork in the pass. side. So the car had the wrong fork on the passenger side. Any way i got the driver side in and its like a whoole new car. I have to go to the U pull it to get the EG pass. side fork.
phantom_hatch
Mar 27, 2014 02:40 PM
biggdogg
Jan 28, 2009 09:04 AM
Silspeg6
Suspension & Brakes
Nov 1, 2007 08:26 AM
EG6_DREAMS
Aug 18, 2007 08:45 AM
sykoracer02
Feb 16, 2005 12:02 PM
