CELs all over the place
Old Aug 4, 2007 | 06:42 AM
meangreenEG's Avatar
Default CELs all over the place
i JUST replaced my fuel filter and IACV, and i'm still getting CEL codes 14 and 48. Not to mention i'm also getting CEL code 22 and i have no idea how to go about fixing that ... Does anybody have a clue why it's doing this?
Old Aug 4, 2007 | 07:14 AM
97Ej6mike's Avatar
Default Re: CELs all over the place (meangreenEG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by meangreenEG &raquo;</TD></TR><TR><TD CLASS="quote">i JUST replaced my fuel filter and IACV, and i'm still getting CEL codes 14 and 48. Not to mention i'm also getting CEL code 22 and i have no idea how to go about fixing that ... Does anybody have a clue why it's doing this?</TD></TR></TABLE>
-----CEL # List-----
14 IAC (EACV) - idle air control valve
22 VTEC pressure valve
48 LAF - lean air fuel sensor
Did you reset the ECU after replacing everything?
Lean air fuel sensor may be caused by a malfunctioning O2 sensor. What type of motor do you have, and what computer are you running?
Old Aug 4, 2007 | 09:14 AM
BlackoutVTi's Avatar
Default Re: CELs all over the place (97Ej6mike)
What engine do you have?
Regardless of engine, I would try resetting the ECU as well.
Old Aug 4, 2007 | 09:24 AM
bkmc24's Avatar
Default Re: CELs all over the place (BlackoutVTi)
Wel i hd code 48 not too long ago, firestone and 3 other websites said that code 48 was heated o2 sensors. Replaced tht and everything is great. If you have the d15Z have fun spending 450 on an o2
Old Aug 4, 2007 | 11:05 AM
Default Re: CELs all over the place (bkmc24)
wow....yeah i have the D15Z1...but i dont know what computer im running, how do i find that out? and to reset the ECU i just remove that fuse while the car is running?
Old Aug 4, 2007 | 11:09 AM
philosofy1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by meangreenEG &raquo;</TD></TR><TR><TD CLASS="quote">wow....yeah i have the D15Z1...but i dont know what computer im running, how do i find that out? and to reset the ECU i just remove that fuse while the car is running?</TD></TR></TABLE>
to reset the ecu just disconnect the battery for atleast 5 min.
to find out the type of ecu, there should be a serial number on it, there you will find the type of ecu.
Old Aug 4, 2007 | 11:12 AM
In order to find out what it says on the ECU, you may need to unbolt it (don't quote me on that), and look over the housing. Somewhere you ought to find "P##"
For example, mine says P08
Old Aug 4, 2007 | 11:42 AM
reset the ECU and im still getting 3 CELs. if i replace the o2 sensor would that solve all the CELs, since my IACV is brand new?
Old Aug 4, 2007 | 11:46 AM
5_Lug_B's Avatar
* B A N N E D *
You might have bad plugs. It happened to me
Old Aug 4, 2007 | 11:56 AM
Syndacate's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by meangreenEG &raquo;</TD></TR><TR><TD CLASS="quote">reset the ECU and im still getting 3 CELs. if i replace the o2 sensor would that solve all the CELs, since my IACV is brand new? </TD></TR></TABLE>
It might, unfortunately you'll never know until you try.
And are you sure you're getting 18? 'Cause that's not a code according the code list .
Though if all of this happened after you changed a fuel filter, I'd have to say you hooked something up wrong or something.
You don't just throw all these CEL's b/c you change a fuel filter.
Old Aug 4, 2007 | 12:19 PM
Default Re: CELs all over the place (Syndacate)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Syndacate &raquo;</TD></TR><TR><TD CLASS="quote">
You don't just throw all these CEL's b/c you change a fuel filter.</TD></TR></TABLE>
i'm not gettin 18, im gettin 14, 22, 48.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 5_Lug_B &raquo;</TD></TR><TR><TD CLASS="quote">You might have bad plugs. It happened to me </TD></TR></TABLE>
Do i have to replace plugs, or clean them out, etc? How should i go about doing this?
Old Aug 4, 2007 | 01:06 PM
i'm running the P07 computer.....any ideas....?
Gunnar24
May 17, 2011 08:19 PM
218luder
Sep 1, 2006 06:04 PM
aziantegger10
Mar 26, 2006 09:44 AM
ToasterOven
Nov 10, 2005 05:08 PM
red_sir
May 15, 2003 11:48 PM
