Will 17X8 and 17X9 fit??
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by g_dub »</TD></TR><TR><TD CLASS="quote">215/50/17's will fit with no rub</TD></TR></TABLE>
you try it then tell me .. 215/50 will rub if your lower even mild. plus it will look like you got some off road tires
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AznBlueBoy »</TD></TR><TR><TD CLASS="quote">17x8 will fit fine on 215/40.</TD></TR></TABLE>
+1 Its a nice little stretch
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H23forlife »</TD></TR><TR><TD CLASS="quote">My car is lowered about 2 inches all around and sitting on 17x7 with a set of 215/45 nitto tires and doesnt rub at all</TD></TR></TABLE>
Comments like this are misleading because offset is a major factor in whether you will rub.
I am dropped 2" as well and when I tried 215/45, it rubbed with my 42 offset rims. If I had 45 or higher or so, I wouldn't have rubbed.
I run 17x8.5, +40 offset (with 235/40/17s) in the front of my car...on full coilovers. I rolled the inside lip before i put them on, but am not even sure if that was required for clearance.
I also run 26x8.5x15 slicks on stock 15" wheels in the same wheel well. Those would be equivalent to 255/55/15's.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by XES »</TD></TR><TR><TD CLASS="quote">I run 17x8.5, +40 offset (with 235/40/17s) in the front of my car...on full coilovers. I rolled the inside lip before i put them on, but am not even sure if that was required for clearance.
But youre not worried about losing acceleration from it!
Glad to see youre still around!
for an Old School Luder who was running 12's a long time ago!
Big meat'd 17's
for killing your acceleration!
for an Old School Luder who was running 12's a long time ago!Big meat'd 17's
+32 offset with 17x8 and 215x40x17 fits without any fender tucking.
Oh and lowered on h&r sports w/ koni yellows mid-perch.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jeremiah87 »</TD></TR><TR><TD CLASS="quote">has anyone tried a 17x8 +48 w/ 225-40-17? 225-35-17?</TD></TR></TABLE>
I have run 17x8 Mugen MF10's with 235/45/17 RA-1's and I didn't rub. OFFSET is a major factor, so people shouldn't just jump in and say that the setup won't work. Here are pics...
I am currently on 17x7" +51 wheels with a 215/45 and I don't rub in any way shape or form. I have also run 17x7's with a +37mm offset and I could slam the living **** out of my car and still make you turns just fine.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by :=:NirVTEC:=: »</TD></TR><TR><TD CLASS="quote">
Big meat'd 17's
It wouldnt matter if I had intermediates on...traction is still difficult. I only race at the track anyways
. And yes...still around, just won't be running my car until 2011 when i get back to my home town. Running low 12's in the summer of 2000 was a long time ago.
I will probably try and sneak some 245's on the front next time i buy tires. They will fit.
for killing your acceleration!</TD></TR></TABLE>
. And yes...still around, just won't be running my car until 2011 when i get back to my home town. Running low 12's in the summer of 2000 was a long time ago.I will probably try and sneak some 245's on the front next time i buy tires. They will fit.
205\45 is the same overall diameter as your stock 195\60-15....check this link out:
http://www.miata.net/garage/tirecalc.html
I know a program way better than that one...
Try this one out. It does offset, clearance, everything
http://www.bigcustomwheels.com/rt_specs.jsp
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KillerAccord »</TD></TR><TR><TD CLASS="quote">205\45 is the same overall diameter as your stock 195\60-15....check this link out:
http://www.miata.net/garage/tirecalc.html</TD></TR></TABLE>
Stock 195/60?! We have Preludes not Accords!
205/55/15 or 205/50/16
From the dead!
Anyone know of light and affordable (ha!) wheels that are 17x8.5 or hopefully 17x9? I'm looking to go to a 255/40R17 Toyo RA1.
4x114.3 please
Right now I'm using Rota Torques 17x8 +35 with 235/40R17. I'm pretty low and there's no rubbing anywhere.
There's a Rota D2 that's a little heavy in 17x8.5 4x114.3 but I haven't found any other options that I wouldn't mind throwing a pair away every year when I bend or break them.
I don't think XES's Volk CE-28N's fit into the "throw away a pair once a year" category
Lemme know if you guys know of anything.
-Chris
4x114.3 please
-Chris
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris F »</TD></TR><TR><TD CLASS="quote">From the dead!
Anyone know of light and affordable (ha!) wheels that are 17x8.5 or hopefully 17x9? I'm looking to go to a 255/40R17 Toyo RA1.</TD></TR></TABLE>
I guess you can never have enough
chris, what about getting some torques in 5x114 i saw they camy in 17x8.5.....and re drilling them to 4x114?
slipstreams also come in 17x8.5
http://www.speedstash.com/rota....html
maybe talk to a dealer about getting some 4x114 manufactured?
or try and find some 5zigen fn01r-c, i know they come in a TON of sizes
Modified by 95greenlude at 4:14 PM 3/28/2008
good tip on the fn01r-c... looks like the 17x9 4x114.3 only comes in a +20, would probably need +35 or +45. I still have to check clearance on the inside but I think I have a little more there.
bling *vomit*
17x9 +35 offset... cheap.. I guess beggars can't be choosers...
http://www.xxrwheels.com/sportmax_962.shtml
27 lbs to boot.. daaamn!
Also XXR 006, probably 23 lbs in the same size, found here..
http://www.edgeracing.com/wheels/xxr/
hmm.
Modified by Chris F at 10:47 PM 3/28/2008
hmm.
