Precision 440cc 525cc 750cc 880cc 1000cc Injectors Brand New. BLOW OUT PRICING.
Phearable.net offers a full line of precision injectors to it's customers.
We have used precision's injectors in setups ranging from 200 whp all motor cars to 800+ whp turbocharged applications.
Precision injectors have proven to be very reliable & perform extremely well when put through harsh race conditions.
High Impedance / Saturated
310cc - 55 HP per injector - $210
440cc - 77 HP per injector - $210
525cc - 85 HP per injector - $269
Low Impedance / Peak Hold
680cc - 120 HP per injector - $269
780cc - 135 HP per injector - $269
880cc - 151 HP per injector - $269
1000cc - 171 HP per injector - $289
1600cc - 275 HP per injector - $420
* Low impedance injectors require a resistor box.
* High impedance injectors do not require a resistor box.
* 92-00 Civics & 94-00 integras do not use a resistor box & use high impedance injectors.
* Vehicles without a resistor box can have one installed, vice versa.
* Precision injectors work with obd1 & obd0 injector clips.
* Obd2 vehicles require precision injector clips.
Precision Injector Clips: $20
<FONT SIZE="5">To order visit our website by clicking here!
</FONT>
__________________________________________________ __________
Walbro High Volume In-Tank and Inline Fuel Pumps - One of the leading original equipment fuel pump suppliers, Walbro fuel pumps set the industry standard for quality and dependability. Walbro has entered into the performance world with the hottest selling and most frequently used performance pumps on the market.
<FONT SIZE="2">All fuel pumps with install kit $89</FONT>
</FONT>
Modified by mtber at 2:08 AM 9/18/2007
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by theoszarz14 »</TD></TR><TR><TD CLASS="quote">interested in a set of injectors but not positive what cc to buy. I am running a t3/t4 turbo on a built D16. The most boost i would run would be 20psi using hondata s300</TD></TR></TABLE>
You can always de-tune injectors, hence you can run a set of 880cc injectors if you wanted to that will support 480-500 whp :-)
