What can cause vibration during idel?
Old Aug 3, 2007 | 11:18 PM
Chewy[Ek]'s Avatar
Default What can cause vibration during idel?
my car started vibrating after some minor work was done to it. change t-belt and crank pully. i told the mechanic about it and he dunno.
Old Aug 3, 2007 | 11:47 PM
BluLude's Avatar
Default Re: What can cause vibration during idel? (Chewy[Ek])
have someone else look at it, the vibration you are talking about could be a misfire or maybe timing that is off or normal...nobody can tell unless they see it first hand.
Old Aug 4, 2007 | 12:58 AM
BlackCatt's Avatar
Check computer for codes. Check Idle control system.
Old Aug 4, 2007 | 09:21 AM
g_dub's Avatar
Where is it vibrating from, what does the noise sound like (clunks/rattles/ect.), be a little more descriptive. It could be your heat shield on your header or on your cat. My vibration noise was the heat shileld on my cat so i took it off and problem solved.
Old Aug 4, 2007 | 11:14 AM
hybrid2007's Avatar
Balancer shaft belt left off?
Old Aug 4, 2007 | 11:36 AM
Chewy[Ek]'s Avatar
Default Re:
the whole car vibrates the most during warm up. its not the heat shield for sure cuz i dont have one. im thinking broken motor mount...what do you guys think?
about the work, i had another mechanic take a look at it and he said it was done correctly.
Old Aug 4, 2007 | 11:39 AM
Chewy[Ek]'s Avatar
Default Re: Re: (Chewy[Ek])
not sure if this helps but i also feel slight vibration WHILE driving on the steering wheel
Old Aug 4, 2007 | 12:08 PM
BB1 pOwA!!'s Avatar
i would think it was a motor mount to. my freind has an rsx that vibrated a lot at idle, it also sounded pretty loud and once he went past a certain rpm it got a little smoother, he got someone to look at it and they said it was the motor mount, he got it fixed and problem solved
Old Aug 4, 2007 | 12:48 PM
bluedlude's Avatar
Default Re: Re: (BB1 pOwA!!)
i separated my rear engine mount when i was changing my clutch, so its KINDA broken. now i have a really light vibration, and if i give it just a little gas it vibrates as the revs drop. just something to take a peak at.
Old Aug 4, 2007 | 01:25 PM
Giant_Bean's Avatar
Default Re: Re: (bluedlude)
after a tune up and valve adjustment, my car idles better than it ever did, something you could try, and should be done anyways.
Old Aug 5, 2007 | 07:40 PM
Chewy[Ek]'s Avatar
Default Re:
so most likely is the motor mount then. my symptoms is kinda of the the RSX. if i gas it, the vibrations gets better.
Chewy[Ek]'s Avatar
thanks guys
hmoob_DB8
Jun 11, 2009 12:16 PM
85pokey
Dec 23, 2003 11:46 PM
CRVTEC96
Mar 12, 2003 06:29 PM
M.A.R.C.
May 22, 2002 06:30 AM
hooptie157
Feb 6, 2002 06:47 PM
