LS VTEC Assembly Problem!!!!
Old Aug 3, 2007 | 11:00 PM
Jeanious's Avatar
Default LS VTEC Assembly Problem!!!!
Any help is greatly appreciated. I am doing an LS Vtec with P30 pistons that I removed from another block. When I removed the rods and pistons off of both blocks this afternoon. I forgot to mark each rod and piston to the cylinder that it belongs to. I will be swaping pistons on the rods. Is is it very important to have them marked? Can they be put back together in any order after getting the ARP Rod bolts installed? Thanx
Old Aug 3, 2007 | 11:47 PM
ef92b's Avatar
Default Re: LS VTEC Assembly Problem!!!! (Jeanious)
you will soon be doing the bearing oil clearances measurements on each rod so it does not really matter.
Old Aug 4, 2007 | 12:39 AM
nu_B's Avatar
Default Re: LS VTEC Assembly Problem!!!! (ef92b)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jeanious &raquo;</TD></TR><TR><TD CLASS="quote">Any help is greatly appreciated. I am doing an LS Vtec with P30 pistons that I removed from another block. When I removed the rods and pistons off of both blocks this afternoon. I forgot to mark each rod and piston to the cylinder that it belongs to. I will be swaping pistons on the rods. Is is it very important to have them marked? Can they be put back together in any order after getting the ARP Rod bolts installed? Thanx</TD></TR></TABLE>
If i understand this correctly, you took the rods and pistons out of a different block, and are putting them in another block. Correct?
If so, you should measure each piston and write the dims down. then measure the bores then right them down. Really. The Dim's of your pistons( i.e. diameter ) will most likely vary from piston to piston TOO bore to bore. (unless the previous motor hadn't seen any strokes )
It may not be that great of a variance, but if i was you, id double/triple check the cylinder bore, and the diameter of your slugs. Then install them according to the similarities of bore to piston diameters.
Have the cyliners been honed? what about the crank journals? line honed at all?
Old Aug 4, 2007 | 08:21 AM
Jeanious's Avatar
Well, I went outside this morning to take another look. And each rod has a 3 or a 2 on it. When you look at the crank, each crank journal has a mark to the side. Two B2 and Two B3s. I know these are to the codes for the bearings, but I would assume that the rods with the 3 go on the 3 and the 2 on the 2. Would you guys happen to know anything about this?
Old Aug 4, 2007 | 05:53 PM
Jeanious's Avatar
I know people build engines, so any input or advise would be greatly appreciated.
Old Aug 5, 2007 | 08:46 PM
zerovandez's Avatar
Default Re: (Jeanious)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jeanious &raquo;</TD></TR><TR><TD CLASS="quote"> but I would assume that the rods with the 3 go on the 3 and the 2 on the 2. Would you guys happen to know anything about this?</TD></TR></TABLE>
Doesn't work that way. Those are codes for you to look up on Honda's bearing chart. You need to measure bore, piston skirt, and bearing clearances as stated by another HT member. Have fun.
Old Aug 5, 2007 | 09:01 PM
Jeanious's Avatar
Well since that same block will not have the same pistons will, I would assume all I need to measure is the are crank journals and rods right?
Old Aug 6, 2007 | 07:09 PM
Jeanious's Avatar
anyone else?
Old Aug 6, 2007 | 07:43 PM
killerpenguin21's Avatar
i had trouble matching the factory bearing codes due to the whole b16 rods in different block...it gave me way off clearances...luckily i had extra bearings lying around (although i must say i may have read it wrong)
i just bought some acl's and plastigauged and im going storng on 200 miles so far.
philliedawg
Mar 1, 2008 02:30 PM
DC2 Mang
335
Dec 4, 2006 08:16 PM
MaxBoost
20
Jul 7, 2003 11:50 PM
Yellb16crxsi
May 19, 2003 12:19 PM
ysrhatch
Aug 27, 2001 07:10 AM
