Uneven brake-pad wear: freezing caliper?
Old Aug 3, 2007 | 08:55 PM
vinuneuro's Avatar
Default Uneven brake-pad wear: freezing caliper?
Just did the pads, and the front left and right pads looked very different. Here are what the friction material thickness is at with the brakes squealing:
Driver outer pad: 5.0mm
Pass. outer pad: 1.5mm
Just for reference helms specifies 1.6mm as the service limit. Something going on here right?
Old Aug 3, 2007 | 08:58 PM
SnlpeR's Avatar
what do you mean by front left and right pads
are you talking about just the drivers (or passengers) side left and right pad?
or are you talking about the drivers side and passengers side pads?
Old Aug 3, 2007 | 09:00 PM
vinuneuro's Avatar
Default Re: (SnlpeR)
Sorry, meant pass. and driver side outer pads.
Old Aug 3, 2007 | 09:05 PM
SnlpeR's Avatar
you can start by checking if the slider pins move freely
its pretty easy to remove, clean, and regrease them
i thnk you have to use the proper grease tho
Old Aug 3, 2007 | 09:34 PM
vinuneuro's Avatar
I ad no problems removing or installing the pads, dunno. Should the pin just slide out when removing it to lube it up?
Old Aug 3, 2007 | 10:23 PM
SnlpeR's Avatar
youd have to slide the boot out of the pin to remove the pin
then pull the boot out of the bracket so you can clean the inside and regreasr them
ive had stuck pins before
Old Aug 3, 2007 | 10:28 PM
M2B4's Avatar
i ran into the same thing on my rears when i did them it was a seized caliper.
Old Aug 4, 2007 | 12:58 AM
vinuneuro's Avatar
I'm assuming either way, the problem is with the pass. side caliper right? Under hard braking, the car does pull to the right. I'm not exactly sure what to look for. The pin moved freely, and the piston compressed back uneventfully.
Old Aug 4, 2007 | 09:35 AM
lude98SH's Avatar
Default Re: (vinuneuro)
how were the inside pads ?
Did you check your brakes lines ?
Could be possible that there is some type of restriction in the brake hydraulic system.
Have you bleed the brakes ?
Old Aug 4, 2007 | 09:38 AM
vinuneuro's Avatar
Default Re: (lude98SH)
The inner pads matched the outer pads. No air in the brakes, firm pedal.
Old Aug 6, 2007 | 01:22 PM
lude98SH's Avatar
hmm.... how do the rotors look ?
Old Aug 6, 2007 | 02:26 PM
bluedlude's Avatar
yeah, id say you might have air in one of the brake lines. if you can depress both of the caliper pistons the same amount then that would be my guess. ive also got a seized caliper(kind of). i couldnt depress the piston past a certain point until i took the brake line off and blew some compressed air in to free it up. now i think it seizes a little.
weird suggestion. drive down a quite street with your window open on the side you think the caliper is seized on. if there is a curb it shold reflect a scraping sound back to you. i know its odd, but thats how i know mine is still seized a bit.
Old Aug 6, 2007 | 03:29 PM
95SE's Avatar
Default Re: (bluedlude)
another way to check for a seized caliper is to feel the rim after driving, it will be excessively hot if the caliper is seized. fronts will naturally be hotter than rears after driving b/c they are take 70% or so of the load, but after just a short distance a seized caliper will heat up a rim quite a bit.
jonyi27
Aug 30, 2013 11:49 PM
BoltonGSR
Mar 10, 2009 07:30 AM
goldegg
Feb 1, 2007 03:02 PM
ProjektR
Mar 11, 2006 02:15 PM
carblegal
Honda S2000
Jul 23, 2005 02:55 PM
