Spark plug Replacement Civic si 2004
Old Aug 3, 2007 | 06:01 PM
mega502's Avatar
Default Spark plug Replacement Civic si 2004
Where are the plugs? I looked in ALL DATA and it said they should be in front under the plastic shield.
I don't see them...please help
Old Aug 3, 2007 | 08:01 PM
tonykdee's Avatar
Default Re: Spark plug Replacement Civic si 2004 (mega502)
just so you know, your civic si is considered a EP3. good luck.
Old Aug 3, 2007 | 10:31 PM
.Kevin.'s Avatar
Default Re: Spark plug Replacement Civic si 2004 (mystiknitekidz)
They are under the "spark plug cover" on the valve cover. Take the cover off, remove the coils and there you go. If you are replacing them, make sure you are using an oem plug or better. The plugs that are in there do not need to be changed until 100k.
Old Aug 6, 2007 | 09:32 AM
T_Virus's Avatar
if you want to then go for denso's
LillDragun
Jan 31, 2021 10:43 AM
08Si-R
Honda Civic (2006 - 2015)
Jan 4, 2011 10:51 AM
thisiskev
Jun 20, 2008 03:18 PM
DrewQ1
Nov 9, 2004 04:48 PM
E46M3CB
Feb 25, 2002 06:17 PM
