LS wires on GSR = Spark Plug Blowout??
Old Aug 3, 2007 | 06:01 PM
Cyphear's Avatar
Default LS wires on GSR = Spark Plug Blowout??
I just put a VTEC head on recently and sometimes i'll hit 10-15lbs or so and the car will buck like the park is blowing out or it is really out of tune. The wideband looks okay though. I couldn't figure it out, then i remembered i was running LS wires which are a little too short. Do you think this could be the cause? I think it might be, but I wanted to get a second opinion before I started throwing parts at the car.
The plugs are gapped the same as they were when i was straight LS-T. I made more power than I am now at 15lbs, so i'm pretty sure its not a gap thing.
Old Aug 3, 2007 | 06:27 PM
Muckman's Avatar
Moderator in Chief
Default Re: LS wires on GSR = Spark Plug Blowout?? (Cyphear)
Running the correct spark plug wires is throwing parts at the car? Are they making a good connection to the spark plugs? I bet its arcing and you dont even know it.
Old Aug 3, 2007 | 07:36 PM
quicksilver1689's Avatar
i ♥ snails
what plugs are you running, what gap, whens the last time you serviced dizzy cap and rotor?
Old Aug 4, 2007 | 10:18 AM
Cyphear's Avatar
Default Re: LS wires on GSR = Spark Plug Blowout?? (Muckman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Muckman &raquo;</TD></TR><TR><TD CLASS="quote">Running the correct spark plug wires is throwing parts at the car? Are they making a good connection to the spark plugs? I bet its arcing and you dont even know it.</TD></TR></TABLE>
i think you are right. it feels like it gets on there, but it's not a solid connection like it should be.
i'm running a .028 gap.
EDIT: I suppose I should update this. For some reason, the gap needed to be tighter on a GSR head. Interesting.
LS_VTECteggy
Nov 19, 2009 04:19 PM
ty_uni_ek08
Oct 14, 2008 12:46 PM
b16b18
Sep 6, 2006 12:56 PM
Xymox007
Jul 30, 2004 11:42 AM
EM1_GIL
Mar 23, 2004 05:31 PM
