95 Gsr Block oil cooler question
I just recently bought a 95 gsr block to replace my damaged 97 gsr block, where do the two oil tube/lines connect to from the 95 gsr block oil cooler?
one goes to the water pipe running from the pump to the T stat housing. The other plugs into a fitting on the back of the block.
not off-hand, but you can see them in most any repair manual or at the dealership in the parts department or an online parts selector. You should be able to see the fittings fairly easily just by looking at the back of the motor.
You can see it in this link:
http://www.acuraautomotiveparts.org/
click on select model and enter in 95 GSR then look for "water hose (3)" that the one you want to see.
Modified by 00Red_SiR at 1:31 PM 8/4/2007
Modified by 00Red_SiR at 1:32 PM 8/4/2007
