CRX HF ECU NO LIGHT,NO SPARK or FUel
OK here we go .I got a 89 crx hf .The clutch was slipping bad ,so I took it to a local shop.And they put it in,but after they put the trans back in the car it would not start.
I am not getting power to the ECU,I can not hear my fuel pump prime.And no spark.
I tipple checked all fuses in motor compartment and under the dash.I replaced the Main relay ,and still no luck.The relay is not clicking at all. checked ground on the trans to body to battery,nothing.I don't get a blink from the ecu.The car turns over ,but no spuder or anything
The check engine light does NOt come on ether.
CAN YOU HELP ME this is my only car .Ive tried to get it to start for 2 months now!
THanks
THanks
Check the alternator fuse under the dash. Check all the big fuses also under the hood. Chech the thermostat ground. It grounds the ecu,main relay.
eatxsleepxjdmx
11
Aug 14, 2012 06:12 PM
cybertek12
Mar 22, 2004 04:13 PM
