93 dx hatch with gsr brake swap?
Old Aug 3, 2007 | 12:46 PM
Rikaro's Avatar
Default 93 dx hatch with gsr brake swap?
do i need a gsr master and slave brake cylinder? Or the original will work just as good? Should i go for the Type R one instead? And is there anything even better?
thanks
Old Aug 3, 2007 | 01:13 PM
EL Vap133's Avatar
Default Re: 93 dx hatch with gsr brake swap? (Rikaro)
You will be just fine with a non-ABS Integra RS Master Cylinder since your hatch did not have ABS.
Old Aug 3, 2007 | 01:29 PM
Chem Geek's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EL Vap133 &raquo;</TD></TR><TR><TD CLASS="quote">You will be just fine with a non-ABS Integra RS Master Cylinder since your hatch did not have ABS. </TD></TR></TABLE>
+1
The 15/16" master cylinder, 4040 valves, and new pads/rotors on your integra brakes is plenty. I really can't see needing more than that.
mini-cRx
Dec 8, 2008 04:03 AM
EleanoR
Dec 23, 2005 06:08 AM
ben_eg6
12
Dec 11, 2004 05:07 PM
