Has anyone had this noise when backing up?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by De_tour »</TD></TR><TR><TD CLASS="quote">Trying to figure out whats causing this.
no offense, but this is your first manual transmission car isn't it?
if the whining noise is what you are talking about, it is perfectly normal. all manual cars does that noise in reverse, at least the ones i have had.
Sorry i forgot to add that it was creaking, not the gear noise. </TD></TR></TABLE>
the cracking noise can be from the clutch, but if the car is still performing fine i wouldn't worry about it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hmtcrxsir »</TD></TR><TR><TD CLASS="quote">sounds like its coming from your slave cylinder whenever you stepped on the clutch. grease the ball joint to the tranny and the problem should go away</TD></TR></TABLE>
