The high flow cat...
Old Aug 3, 2007 | 09:27 AM
zoso's Avatar
Default The high flow cat...
Hey guys i have a 2000 ex civic, my cat broke awhile back, the rear honey comb stuff came out, so now i need a new cat. I was going to get a used stock one but no one has any so i have desided to get a magnaflow high flow cat. Where is the cheapest place to find one. Or if you think one of these 3 ways would be a better way to go let me know. I could get a magnaflow universal cat, magnaflow high flow cat, or keep looking for a used stock cat? Thanks for all the help
Old Aug 3, 2007 | 09:30 AM
philosofy1's Avatar
Default Re: The high flow cat... (zoso)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zoso &raquo;</TD></TR><TR><TD CLASS="quote">Hey guys i have a 2000 ex civic, my cat broke awhile back, the rear honey comb stuff came out, so now i need a new cat. I was going to get a used stock one but no one has any so i have desided to get a magnaflow high flow cat. Where is the cheapest place to find one. Or if you think one of these 3 ways would be a better way to go let me know. I could get a magnaflow universal cat, magnaflow high flow cat, or keep looking for a used stock cat? Thanks for all the help</TD></TR></TABLE>
http://www.hondamarketplace.com/
http://www.google.com/
Old Aug 3, 2007 | 09:35 AM
Libertariat's Avatar
Ek Forever y0!
Default Re: The high flow cat... (philosofy1)
autozone has cheap cats. ~$100
if you just want cheap.
Old Aug 3, 2007 | 09:38 AM
zoso's Avatar
Default Re: The high flow cat... (ek forever guy)
no i dont want cheap i want good, i look on the market place and no one has a obd2 or if they do its for a teggy and i dont want to have to cut and weld a new flang. What would you guys use?
Old Aug 3, 2007 | 09:41 AM
sicones's Avatar
get a magnaflow/carsound from ebay
BlackoutVTi's Avatar
Muffler shop.
Easy.
Convenient.
Good price.
Already at the place where it gets installed (provided it's weld-in).
/thread
Old Aug 3, 2007 | 09:43 AM
sicones's Avatar
don't worry about where the O2 is placed on the 96-98, it will fit your 99-00 civic as well, even better
http://www.car-sound.com/02pro...22628
http://cgi.ebay.com/ebaymotors...ZWD1V
now:
/thread
Old Aug 3, 2007 | 09:48 AM
zoso's Avatar
Default Re: The high flow cat... (sicones)
http://www.car-sound.com/02pro...54054
I think i am just going to get the universal ^^^ in stead of the high flow, all ill have to do is have a shop weld 2 flang on the ends?
will this one fit cause its for a 96-98 but i have a 00ex
Old Aug 3, 2007 | 09:51 AM
sicones's Avatar
it will fit, I put a 98 cat in my 00 civic last year becuase it was cheaper from honda $400 instead of $900
99-00 cat has the o2 in the center because you have a little LEV sticker on your rear window which means ****
the o2 sensor wires will reach to either place on the cat
Old Aug 3, 2007 | 09:54 AM
zoso's Avatar
ok but it wont throw my check engine light on if i use a 96-98? is the pipe di 2'' or should i get 2.25?
Old Aug 3, 2007 | 09:56 AM
sicones's Avatar
if you get the universal for ~$50 then you have to pay a shop to weld it, there probably going to rip you a new *** hole
or ~$140 for a bolt in that you can change yourself
you decide
Old Aug 3, 2007 | 09:58 AM
sicones's Avatar
your better off getting a 96-98 anyway it has more catalyist material in front of the o2 = less chance of P0420 catalyist innefficency code
the pipe is really 2", 2.25" might be a tight fit...
A high-flow cat is recommended. Think, if you had a choice, and both were legal, would you spend money to buy your stock peashooter exhaust again, or a WS2? The high-flow cat gives comparable flow to a test pipe, and still operates within the proper parameters. I suggest you spend a little extra to go with the advantages of a high flow cat.
An exhaust system is only as good as its most restrictive point.
Old Aug 3, 2007 | 10:03 AM
sicones's Avatar
Default Re: The high flow cat... (BlackoutVTi)
FYI a slightly higher flowing 2.25" cat on your car will do jack ******* **** on a D16
Old Aug 3, 2007 | 10:07 AM
A slightly higher flowing intake will do jack ******* **** on a d16, as will a slightly higher flowing header, and a slightly higher flowing exhaust, but they do work well together for what you've spent loads of money on <u>as a system</u>.
I just don't know if the "good enough" attitude is something the D16'ers can afford to have, what with the economy class engines. Why are we arguing about this?
EDIT:
High Flow Cat on google search: $80
Standard universal cat on ebay: $50
IMO, it's worth $30 for me to know if I've got a better flowing system than those with the standard cat.
To each his own. OP, do what you feel. If price is really a problem, just go with the standard. If $30 isn't too much of a reach for you, I say go with the high-flow.
Old Aug 3, 2007 | 10:12 AM
philosofy1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zoso &raquo;</TD></TR><TR><TD CLASS="quote">ok but it wont throw my check engine light on if i use a 96-98? is the pipe di 2'' or should i get 2.25?</TD></TR></TABLE>
stop worring about your cat and fix your brakes!
https://honda-tech.com/zerothread/2059008
Old Aug 3, 2007 | 10:36 AM
alacard's Avatar
A high flow cat will give you problems trying to get it installed. I got it from like 3 different shops in cali when I was trying to get mine welded in on my 98 and on my 99. One said it was carb legal for trucks, but not cars, another said he could put it on an obd1 civic, but not obd2.
Old Aug 3, 2007 | 10:39 AM
zoso's Avatar
Default Re: (alacard)
Ok i am going to get a 96-98 2'' high flow cat from magna flow direct bolt on. Is that one in the picture high flow or universal? Do you guys agree on this set up. I have a aem v2 intake d16y8 dc ceramic header that cat(the 98) and a stock si muffler. will this cat work good for my set up?
Old Aug 3, 2007 | 10:46 AM
rebuiltSI's Avatar
I just had the P0420 Catalytic Efficiency Code on my 99 Si so I went to a local muffler shop where they had a carsound/magnaflow hi-flow cat (o2 sensor in the middle, OBDII). The converter did not come with the flanges so what they did was just cut the piping before the flanges on the old converter.. then mock up the new converter and weld it in. So they didnt have to unbolt anything or worry about flanges. My car seems to get alot better gas mileage even though its only been about 60 miles since I got it installed. Im happy with the decision. Carsound cat FTW!!
Old Aug 3, 2007 | 10:49 AM
.:Swig:.'s Avatar
fab up a test pipe
Old Aug 3, 2007 | 10:53 AM
zoso's Avatar
Default Re: The high flow cat... (takea$wigg)
No im good no test pipe for me i need to pass smog. But rebuiltSI how much did it cost you. I am getting a high flow magnaflow cat direct bolt in or not i dont car. I just have to look for the cheapest one. Why would the 98 be better than the 00 i dont get it?
Old Aug 3, 2007 | 10:56 AM
h2392si's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sicones &raquo;</TD></TR><TR><TD CLASS="quote">get a magnaflow/carsound from ebay</TD></TR></TABLE>
X2
Old Aug 3, 2007 | 11:27 AM
zoso's Avatar
Default Re: The high flow cat... (h2392si)
is there any diff in smoging the car with a 98 and 00 cats?
Old Aug 3, 2007 | 11:57 AM
zoso's Avatar
and also anyone know if they are c.a.r.b legal
Old Aug 3, 2007 | 01:17 PM
rebuiltSI's Avatar
It cost me too much now that I found the same one online cheaper. Anyways Im happy with it and my CEL isnt on anymore so whatever. Anyways just get this one right here and have a muffler shop weld it in. You will be happy, pass emissions, and have no CEL. http://cgi.ebay.com/ebaymotors...ZWD1V
