96 Accord electrical problem- new ground wires
Old Aug 3, 2007 | 05:54 AM
CaptnPooDaddy's Avatar
Default 96 Accord electrical problem- new ground wires
I installed some new ground wires in my car and they all hook up to the negative side of my battery. The 7 wires go to the strut tower, intake manifold, valve cover, headlight tower, steering unit or alternator, distributor, and transmission. Once I got everything hooked up I go to crank up my car and lights flicker and then everything dies. Car won't turn on, lights won't turn on, nothing will turn on. So uh... an idea guys as to what I can do to fix the problem?
Old Aug 3, 2007 | 06:24 AM
TheMuffinMan's Avatar
He knows where you live!
Take off the "grounding kit"
Old Aug 3, 2007 | 06:56 AM
The-Kid's Avatar
Default Re: (TheMuffinMan)
take it off on the distributor. and alternator first. If everything works well. You found your problem.
Old Aug 3, 2007 | 09:13 AM
jabontke's Avatar
Default Re: (The-Kid)
Why do you have 7 wires? One fat grnd wire from the battery neg to the engine block is all the engine needs.
Old Aug 3, 2007 | 10:04 AM
It sounds like a grounding kit, like I said, they're supposed to do a bunch of crap, but nothing really proven
96TightAccord
Jan 26, 2009 04:44 PM
b18cEK
Nov 5, 2006 06:17 PM
shutta
Aug 24, 2006 07:13 PM
rodimus
Audio / Security / Video
18
Feb 14, 2003 12:19 PM
EJK
Feb 4, 2003 10:37 AM
