What is this leaking ??
Old Aug 3, 2007 | 02:54 AM
Scott (T.O.A)'s Avatar
Default What is this leaking ??
Basically i think i might have a blown head gasket on my d16z6 but im not sure. ive got some of the symptoms. White smoke, over heating occasionally, leaking water. but im not sure if this is the same problem or even what it is at all!
basically i get a leak from the hole inside the blue circle.
here is a picture of where the hole is located. it is around the water pump area i think where all the belts are
is there meant to be something attached to there or is the hole not meant to be there!? any help would be great thanks
Scott
Old Aug 3, 2007 | 03:13 AM
Rainy City's Avatar
Default Re: What is this leaking ?? (Scott (T.O.A))
pop open your timing belt cover and start the engine. see if it leaks form the water pump area. there usually is a built in seep hole to prevent coolant from touching the timing belt if it leaks because if that happens it automatically ruins it.
Old Aug 3, 2007 | 03:55 AM
marquisdee1018's Avatar
Default Re: What is this leaking ?? (Rainy City)
That's the weep hole for the water pump.
Old Aug 3, 2007 | 04:02 AM
Hi thanks,
does this mean that the water pump will need replacing or are there any other possible causes?
Thanks
scott
Old Aug 3, 2007 | 04:36 AM
VegaS10's Avatar
Replace your water pump ASAP!
Old Aug 3, 2007 | 05:14 AM
Default Re: (VegaS10)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VegaS10 &raquo;</TD></TR><TR><TD CLASS="quote">Replace your water pump ASAP!</TD></TR></TABLE>
And you should replace your timing belt while your at it.
Old Aug 4, 2007 | 01:14 PM
Ok, ordered a water pump its on the way and should take a week to come.
how urgent is this? i mean am i going to expletive the car by driving it easy to work n back (its my daily)
Old Aug 4, 2007 | 02:13 PM
95ProjectEJ1's Avatar
Default Re: (Scott (T.O.A))
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Scott (T.O.A) &raquo;</TD></TR><TR><TD CLASS="quote">Ok, ordered a water pump its on the way and should take a week to come.
how urgent is this? i mean am i going to expletive the car by driving it easy to work n back (its my daily)</TD></TR></TABLE>
Like they suggested, get the timing belt too. Might as well replace it since it has to come off. If you are going to drive on it while you are waiting for it to come in, I would check your coolant levels as often as you can and maybe even drive with the heater on to release some heat.
Old Aug 4, 2007 | 02:31 PM
macson's Avatar
Just treat it like a bad oil leak, check your coolant constantly and get it fixed soon.
Old Aug 5, 2007 | 06:29 AM
Ok guys thanks very much for your help
kornerk12
Nov 27, 2008 07:40 PM
Lude-Lee
Feb 18, 2008 07:50 PM
b18c4door
Jan 8, 2007 07:42 AM
rafiq7
Nov 30, 2004 09:16 AM
Seye
Mar 28, 2004 03:26 PM
