91 VSS location
I have been looking for the vss on my 91 prelude, I believe it's supposed to be on the trans bell hosing top fire wall side. Does anyone know if this is true, and what do I have to remove to get to it.
Thanks Wes
Thanks Wes
Yes its in the back right next to the rear motor mount bracket, you will have to remove all the intake airducting and air filter housing, remove the power steering lines that go to the sensor and theres just 1 10 mm bolt that holds it in place, also make sure the sensor is FULLY installed before tighting down that bolt, its real easy to break off the sensor mounting flange from it not being fully seated
thenextnash
May 11, 2016 02:27 PM
littledude56
Jan 9, 2010 05:05 PM
