95 Civic A/C vents Stuck
The ac vents on my 95 ex are almost stuck and hard to move up,down, and side to side. Is there any way to lubricate the vents and what do i use.
If you have a steam cleaner use that first. Most of the time its just gunk. Otherwise, try using something like windex at first and just spray the crap out of them. Try to move them back and forth and wipe away any excess. Then use a SMALL amount of silicone lube once you have gotten them moving and again just wipe away the excess. Should be good as new!
