Possible engine swaps for 86 CRX?
Old Jun 11, 2002 | 09:53 AM
ActiveAero's Avatar
Paragraph Alert
25 Year Member
Community Builder
Community Influencer
Default Possible engine swaps for 86 CRX?
One of my friends might be picking up an 86 CRX for cheap. I have been looking into swaps, but it seems that most are for the 88 and up models. He isn't looking for a CRX/ITR hybrid. Just a good engine with decent power. I'm thinking along the lines of a ZC. Any info on the what is needed and difficulty of swap would be appreciated. This is in Alabama as well so emissions do not apply.
Old Jun 11, 2002 | 10:02 AM
sappsycho's Avatar
Default Re: Possible engine swaps for 86 CRX? (ActiveAero Ninja Edition)
ANYTHING is possible $$$
The most common swaps are b16 swaps, b18a (LS/VTEC), B18c1 (gsr engine), b18c5 (ITR motor, beautiful but oh so expensive), and finally CR-VTEC.....it all depends on what you are looking for...b16 is cheap, reliable, and has been done so many times that alot of info is out there on it, b18c's provide relatively cheap power, b20 is a torque monster....
There is also the h22, but because of its weight, it doesnt go well with CRX's (especially first gens).......
Old Jun 11, 2002 | 04:02 PM
blacksoul's Avatar
What is the stock engines code? ie: d16, d15?
If its a stock d-series motor, the sohc vtec (will bolt in with no problems using the stock crx tranny. But wiring it up to run is another thing.......GOOD LUCK, and hopefully someone else can answer this question better than me .
Old Jun 11, 2002 | 05:05 PM
Jared's Avatar
86 CRX is not a D series engine. Here are your options:
If it's carbed, it's gonna be abitch to convert it to fuel injection, so get a brown top zc, and some side draft mikuni or weber carbs to throw on there.
If its injected, you have several options:
First, the 86-97 integra motor bolts in with the integra mounts, wiring is the same and all. Use the teg ecu as well.
Second, get a brown top ZC, throw it in there, bolts up to the mounts, trans, etc..
Third, HASport makes a mount kit to put a B series motor in there. Cheapest route would be a B16.
HTH
puertoricanboy90
11
Dec 1, 2008 11:38 AM
boysatt
Dec 12, 2005 02:11 PM
Bobby12many
Mar 26, 2004 11:09 AM
