how to modify my exhaust to use v-band clamps? question inside
i had quick question, i have a 3" exhaust that has a muffler that i use for street and an interchangeable rear section which is non-restricted that i'd like to use on the track. the thing is, that the exhaust is held on by spring clamps, which i hate to use, last time i put it on, it seemed like the spring was gonna snap and shoot me in the face, not my cup of tea
then i went on spoolinperformance.com and saw they had 3" v-band clamp and conversion kits, and it came out to about $40
if i can do this to my rear section for $40, it would be a well worth $40 spent. all i would need is to use my rachet and socket to loosen it up and swap it out, voila
i'm assuming since my exhaust is slip-fit, i would need to cut off a portion so it would sit lip to lip instead of sliding inside of the other pipe, correct?
my question
can i use the following parts in the picture to adapt to my exhaust? i assume the smaller face of the flange goes inside my exhaust or something, then i put them back to back
Modified by JJSpecTuning at 8:44 PM 8/2/2007
my question
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrbsponge »</TD></TR><TR><TD CLASS="quote">cut the pipe weld in v-band flange, put the clamp on and tighten down.
i have 2 on my echaust, front and rear, hella easier to take off</TD></TR></TABLE>
that's exactly what i'm going for, thanks!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MantisX »</TD></TR><TR><TD CLASS="quote">Whats the procedure to use this on the turbo exhaust?
MantisX</TD></TR></TABLE>
procedure= use your head
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dturbocivic »</TD></TR><TR><TD CLASS="quote">
You do the same reguardless
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by herecomesboost »</TD></TR><TR><TD CLASS="quote">
You do the same reguardless </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JJSpecTuning »</TD></TR><TR><TD CLASS="quote">not my cup of tea
I have a cup of tea when I go out for dim sum
way to type your life story
