Anyone running D15B8 with 96-98 Vtec Head Swap?
Old Aug 2, 2007 | 07:32 PM
gentek1145's Avatar
Default Anyone running D15B8 with 96-98 Vtec Head Swap?
Mini Me:
How you like the HP gains/vtec over stock? Are you happy with it, and also, did you run into any issues during the install?
I'm currently doing this swap into my EG, and am looking for some pointers. I've already removed the head, and resurfaced it/degreased. Installed new head gasket, IM gasket, y8 Intake Mani, and the distributor OBD2 with conversion harness. I'm onto the timing belt now, and purchased the Vtec 96-98 one, as the oem one has too much slack in it...
Next is wiring the Vtec to the P28 Ecu. Anyone have helpful pics of the wiring? As i understand it, the Vtec solenoid connects to the A4 wire, and Pressure switch connects to D6 wire off the ecu. ( is that it?)
Thanks for any help!
Old Aug 2, 2007 | 07:35 PM
Libertariat's Avatar
Ek Forever y0!
Default Re: Anyone running D15B8 with 96-98 Vtec Head Swap? (gentek1145)
Most of the people I've talked to like it for about 2 weeks.
Ask bauley, he did the write-up on mini-me's and he'll tell you first-hand it's a complete waste of time/money.
Old Aug 2, 2007 | 07:36 PM
Ek Forever y0!
Default Re: Anyone running D15B8 with 96-98 Vtec Head Swap? (ek forever guy)
https://honda-tech.com/zerothread?id=554053
https://honda-tech.com/zerothread?id=735196
Old Aug 2, 2007 | 07:42 PM
97Ej6mike's Avatar
Correct me if im wrong, but dont the D15b8 pistons have different cutouts on top of them, to accomodate its 8-valve head? Im not very clear on this, but i remember there being an issue of adding a 16valve head to the pistons that had the cutouts ( i dont know the correct term) for an 8-valve head. Like i said before, im open to all corrections on that, but the thought had just crossed my mind.
Old Aug 2, 2007 | 08:10 PM
excivicboy96's Avatar
Default Re: (97Ej6mike)
Probably swapping out pistons for ones that can accomodate 4 valves per cylinder would be a wise choice.
Old Aug 2, 2007 | 08:35 PM
gentek1145's Avatar
Wow, that Mini-Me Swap guy is a guru when it comes to that swap. +rep if i could on that write-up!
2.2accord
Aug 19, 2009 04:24 PM
CIVSTYLE
Aug 19, 2009 07:57 AM
lilo_goki
Mar 17, 2009 05:38 PM
burnvic53
Jul 26, 2007 07:14 PM
the DR.
Jan 29, 2002 07:48 PM
