hesitation off idle
91 civic awd, d16.
car starts and idles, but as soon as i give it any acceleration, it begins to stall. if i accelerate reallly really slowly, it will slowly climb up the rpm band. but any sudden moves and it bogs again.
i've checked the timing and it's spot on. it's got new plugs, cables, cap & rotor.
any ideas?
any ideas?
after about 15 minutes, it throws an error for the o2 sensor, i tried unplugging it, and it still has the same symptoms, so i'm thinking the o2 is just simply another problem, but not specifically whats causing the main issue. what do you think?
