FS: 1991 240SX, JDM Front, 340whp, and lots more.
I am posting this car for a friend of mine. All of his contact information is listed below. Please excuse the bad photos, the car and paint are beautiful in person. Everything done to the car was done with meticulous quality, and care by some of the industry best. All engine work/installs, were done by Apex Integration USA R&D, and G-Dimension in Industry, CA. Tuning was also done by APEXi R&D. Paint was done by Mob Works in Orange, CA. All moldings and trim were replaced with brand new OEM pieces as well. The front bumper is cracked, and it will come with a brand new JDM Nismo aero bumper along with the sale. The car truly performs, and drives like a dream. No trades, no part out, serious buyers only please. Thank you for looking everyone!
1991-base model (no sunroof), 150k on chasis, approx 30k on motor
<U>ENGINE AND DRIVETRAIN:</U>
SR20 S13 BLACK Top
NEW SR water pump
NEW 3pc turbo gaskets (exhaust-s15, inlet, outlet)
NEW valve cover gasket
NEW spark plug cover gasket
NEW OEM Nissan Z32 fuel filter
NEW OEM Fan Shroud
NEW OEM Clutch Fan
NEW OEM Window moldings/trim
Apex GT Radiator W/ Cap
Greddy/Trust Oil Pan
Greddy/Trust Pulley Kit
Power Enterprise Belts
ARP Head Studs
ARP Exhaust Manifold Studs
Greddy Rocker Arm Stoppers
Peak Performance Race SR20 Valve Springs
Peak Performance Race SR20 Retainers
OEM SR20 Valve Stem Seals
OEM SR20 Front main seals
OEM SR20 Rear main seals
Oil Pump Assembly
Nismo Thermostat
XS Engineering Downpipe w/cat delete
Apex Titanium Exhaust
Megan Racing Turbo Extension
Megan Racing Tubular Manifold
XS Engineering FMIC w/Hard Pipes
SAMCO upper and lower hoses
Apex Iridium Plugs #7
Apex Head Gasket
Nismo Engine Mount
Nismo Tranny Mount
Apex R33 N1 Fuel Pump
Apex Super Suction Kit
Z32 Air Flow Meter
Apex Power FC w/ FC Commander
Apex AVCR
New OEM Hicas Steering Rack
Nismo Steering Rack Bushings
Apex 260 Cams IN & EX
Apex Adjustable Sprokets IN & EX
Tomei 3" 70mm Big Bore Throttle Body Kit w/match ported intake manifold
SARD Oil Catch Can
SARD Air Seperator Tank
Apex B70 Race Version Turbo Kit
850 CC Injectors
S14 Transmission
Nismo 2 Way LSD w/S14 Diff Housing
Exedy Clutch
New Pilot Bearing and New Throw out bearing
Nismo Steel Clutch Line Kit
Nismo Slave Cylinder
Nismo Pivot Ball
Aluminum Battery Box in the trunk
Optima Yellow top battery
<U>SUSPENSION, BRAKES, AND WHEELS:</U>
Apex N1 Evolution Dampers
Peak Performance Outter Tie Rod
Peak Performance Pillow Upper Link
Peak Performance Rear Upper Camber Link
Peak Performance Tension Rod
Peak Performance 5 Lug Conversion Race Version w/ Wheel Bearing
Battle Version Front Lower Control Arm
Peak Performance Sub Frame Bushing
Nismo Power Brace
Z32 Front Brake Conversion
CIP Z32 Steel Braided Brake Lines
GTO Direct Steering17" Black N1 Racing Wheels (17x8 17x9)
<U>EXTERIOR:</U>
MOB Works 2004-2005 Mercedes Silver Paint Job
Silvia Front End Conversion (OEM Metal)
Nissan Factory AERO Side Skirts
Front Square Lights W/ HID Kit
R32 Center Piece
S13 Silvia Trunk Emblem Lock
<U>INTERIOR:</U>
Stock S14 seats (pair)
Drift ****
Nismo GT Shift ****
<U>EXTRA PARTS:</U>
Apex GT Spec Exhaust
Apex WS Exhaust
Z32 NA rear aluminum spindle (not installed)
Z32 Rear Brakes and rotors
JDM Nissan Factory AERO Front Bumper w/ Support
340 RWHP @ 1.3 bar on Dynopacks on 91 Pump Gas
Price: $11,000 OBO
Please contact:
Wen
Email: apexs13@yahoo.com
Serious Inquiries Only
SR20 S13 BLACK Top
NEW SR water pump
NEW OEM Fan Shroud
NEW OEM Clutch Fan
ARP Head Studs
Oil Pump Assembly
Nismo Thermostat
Apex Head Gasket
Nismo Engine Mount
Nismo Tranny Mount
Z32 Air Flow Meter
Apex AVCR
SARD Oil Catch Can
850 CC Injectors
S14 Transmission
Exedy Clutch
Nismo Pivot Ball
Nismo Power Brace
<U>EXTERIOR:</U>
R32 Center Piece
<U>INTERIOR:</U>
Drift ****
Nismo GT Shift ****
<U>EXTRA PARTS:</U>
Apex WS Exhaust
Price: $11,000 OBO
Please contact:
Wen
jdmhondaboi626
Jan 25, 2010 09:13 PM
jdmhondaboi626
Jan 25, 2010 08:44 PM
B2FiNiTY
Jun 30, 2005 08:40 AM
