What should i know to change starter
Old Aug 2, 2007 | 05:13 PM
LukieLuc's Avatar
Default What should i know to change starter
i have a 1995 honda prelude si w/jdm h22a on an h23 tranny i will be changing my starter tomorrow, what do i need to know to do this? thanks
Old Aug 2, 2007 | 05:18 PM
MLBZ521's Avatar
Default Re: What should i know to change starter (LukieLuc)
I dunno if you've ever taken that starter off before, but I know when I changed mine from my H23A1 when it burnt up it was stuck on there from 130,000 miles.. A Breaker Bar helps a lot.. I'd recommend one.
Otherwise, it's not hard, I didn't need the Helms or anything, just remove, and replace the same way.. No biggy.
Old Aug 2, 2007 | 05:28 PM
m00nr0ck Si's Avatar
Default Re: What should i know to change starter (MLBZ521)
Yep just undo the Positive and negative wires and undo the (2) 14mm bolts and your done! Just make sure you undo the battery before starting this project...
Old Aug 2, 2007 | 06:08 PM
LukieLuc's Avatar
Default Re: What should i know to change starter (m00nr0ck Si)
thanks guys
Old Aug 2, 2007 | 07:49 PM
M2B4's Avatar
yep easy ever changed a dizzy its about same concept
Old Aug 2, 2007 | 08:43 PM
mgags7's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by m00nr0ck Si &raquo;</TD></TR><TR><TD CLASS="quote">Yep just undo the Positive and negative wires and undo the (2) 14mm bolts and your done! Just make sure you undo the battery before starting this project...</TD></TR></TABLE>
negative wire?
the starter gets its ground from contact with the transmission casing, which is grounded well already.
the wire you're talking about is the solenoid wire i think...
anyways, thats enough nitpicky crap, this changeover is very straightforward as they have said.
joenoreason
Dec 20, 2013 08:06 PM
T3KNiQe
Nov 26, 2008 07:24 AM
bacnoonoi
Feb 4, 2007 12:48 PM
SRd240sx
Aug 23, 2004 11:17 PM
DubbleD
Apr 24, 2003 04:05 PM
