Type r sway bars on 96 ex
Are there any type r sway bars that won't fit a 96 ex? I'm looking at one right now that says it "Will only fit JDM 94-01 Integra and 92-95 Civic with modification." It's the JDM ITR 23mm rear sway bar. Will this not work, even if I get endlinks?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CALC!_JUST_du_IT! »</TD></TR><TR><TD CLASS="quote">Are there any type r sway bars that won't fit a 96 ex? I'm looking at one right now that says it "Will only fit JDM 94-01 Integra and 92-95 Civic with modification." It's the JDM ITR 23mm rear sway bar. Will this not work, even if I get endlinks?</TD></TR></TABLE>
You're going to tear out the subframe without a reinforcement plate.
like i already said. . . .
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Egezzy »</TD></TR><TR><TD CLASS="quote">the itr rear will work the fronts wont. just get a beaks kit,asr,etc. get a ctr front!</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Targa250R »</TD></TR><TR><TD CLASS="quote">The EK9/EM1 26mm front bar is awful.</TD></TR></TABLE>
why do you say that?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sk8shorty012 »</TD></TR><TR><TD CLASS="quote">why do you say that?</TD></TR></TABLE>
Because I owned an EM1 for several years and felt the front bar was terrible?
the rear will fit but idunno bout the front. alot of companies online say it wont fit for the rear because they dont sell the hardware for it and they dont want u to buy it assuming that u dont need nething else. if ur gonna get a rear sway bar i recommend the asr subframe brace.
The rear will fit fine. Get an ASR kit as well. With a beaks kit your subframe will STILL tear.
The front, just get an OEM 6th gen civic swaybar, or order one online somewhere. Suspension techniques is a good brand.
You'll need si control arms and end links as well.
rhdekhatchie
Feb 22, 2008 05:13 PM
