My JDM B18C1. Help.
Old Aug 2, 2007 | 11:28 AM
zerovandez's Avatar
Default My JDM B18C1. Help.
So I bought an automatic JDM b18c1. The throttle body has 2 cables comming out of it and I don't know why. One leads to the gas pedal, the other to the tranny.
I have an ek chassis with a manual gsr tranny and will be reusing my b18b throttle body. Will I need to reuse that throttle pully/plate? will it work? which hole to I put the cable into?
Old Aug 2, 2007 | 11:31 AM
philosofy1's Avatar
Default Re: My JDM B18C1. Help. (zerovandez)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zerovandez &raquo;</TD></TR><TR><TD CLASS="quote">So I bought an automatic JDM b18c1. The throttle body has 2 cables comming out of it and I don't know why. One leads to the gas pedal, the other to the tranny.
I have an ek chassis with a manual gsr tranny and will be reusing my b18b throttle body. Will I need to reuse that throttle pully/plate? will it work? which hole to I put the cable into?</TD></TR></TABLE>
on the b18c1, the one cable running to the throttle body is fine, that's the one you will need.
the other one running to the tranny is most likely off of the cruise control system.
since you are not going to be using the auto tranny, disgard the tranny along with the cable.
Old Aug 2, 2007 | 11:40 AM
fmrprojects's Avatar
Default Re: My JDM B18C1. Help. (philosofy1)
just use the gsr throttle body.
Old Aug 2, 2007 | 11:43 AM
BlackoutVTi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by philosofy1 &raquo;</TD></TR><TR><TD CLASS="quote">the other one running to the tranny is most likely off of the cruise control system.
since you are not going to be using the auto tranny, disgard the tranny along with the cable.</TD></TR></TABLE>
zerovandez's Avatar
It's missing sensors and the TPS is broken. Plus it has a FITV. My LS TB is prefect.
But which hole do I put the cable into? There's 2 of em.
Also, it doesn't sound like it's an issue with the throttle plate being designed for an automatic vehicle with my manual tranny setup right?
Old Aug 2, 2007 | 11:47 AM
saleensolution's Avatar
Default Re: (zerovandez)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zerovandez &raquo;</TD></TR><TR><TD CLASS="quote">It's missing sensors and the TPS is broken. Plus it has a FITV. My LS TB is prefect.
Also, it doesn't sound like it's an issue with the throttle plate being designed for an automatic vehicle with my manual tranny setup right?</TD></TR></TABLE>
im pretty sure you use the bigger one (which is closer to the fire wall)
SpeedoKing
Aug 6, 2007 03:09 PM
monkalotamus
Nov 15, 2006 06:31 PM
Cute EK
Nov 15, 2005 06:18 PM
ubreak_ubuy
May 11, 2005 01:38 PM
VTECPowerdSi
Oct 19, 2004 10:52 AM
