EG Engine mounts that i bought does not match engine support pattern
Old Aug 2, 2007 | 11:13 AM
crazyguy's Avatar
Default EG Engine mounts that i bought does not match engine support pattern
i have a b16a swap and i ordered the aftermarket engine mounts for b16as into eg civic.however the engine mount on the driver side does not match to the enigne moust support..
the engine mount has 3 holes which i think there are suppose to be 3 support studs..but there are only 2 support studs on the engine mount bracket?
the rest of the 2 mounts fits perfectly..
so this drive side mount confuses me..
anyone knows aobut this ?
and it is a jdm b16a second gen swap.
thanks
Old Aug 2, 2007 | 11:17 AM
P12 EG6's Avatar
Default Re: EG Engine mounts that i bought does not match engine support pattern (crazyguy)
the drivers side mount only has 2 studs stickin up right???
Old Aug 2, 2007 | 11:19 AM
philosofy1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crazyguy &raquo;</TD></TR><TR><TD CLASS="quote">i have a b16a swap and i ordered the aftermarket engine mounts for b16as into eg civic.however the engine mount on the driver side does not match to the enigne moust support..
thanks</TD></TR></TABLE>
B16's (at least JDM's) have the 2 bolt mounting pattern. B18's have the 3.
return it and tell them you need the 2 hole mount. it is the exact same as the SOHC civic mounts.
Old Aug 2, 2007 | 11:59 AM
saleensolution's Avatar
Default Re: EG Engine mounts that i bought does not match engine support pattern (philosofy1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by philosofy1 &raquo;</TD></TR><TR><TD CLASS="quote">
return it and tell them you need the 2 hole mount. it is the exact same as the SOHC civic mounts.</TD></TR></TABLE>
x2
jclamor87
Nov 5, 2007 02:36 PM
Civic168
Suspension & Brakes
Feb 28, 2006 09:21 PM
marc-111
Jan 25, 2006 11:37 PM
2000DX
Jun 23, 2004 11:15 PM
koshir
Apr 27, 2004 05:42 AM
