***Did I Blow my Head Gasket?? Please help!***
Old Aug 2, 2007 | 11:10 AM
EM-One's Avatar
Default ***Did I Blow my Head Gasket?? Please help!***
Sup fellas--I have a 2000 Civic Si w/a Greddy Turbo kit, and this morning when I started my car, it idled fine for about 45 sec, then my idle dropped super low where it was on the brink of stalling, and when I stepped on the gas to bring the RPMs up, it would sputter and sound like a diesel, and had difficulty revving past 4k.
When I was revving the car, it was puffing lots of white/bluish smoke, and it continues to idle at only 100-200 rpm until it stalls. I also noticed that my coolant (which was full about 2 weeks ago,) has gone down about an inch to an inch to an inch and a half.
I want to get a leakdown/comp test, but I'm afraid to drive my car--will it be ok to drive, or should I tow it to some place?? Does this sound like the head gasket? And if so, do I need to replace anything else, or should that be it? Thanks for the help!
Old Aug 2, 2007 | 11:15 AM
philosofy1's Avatar
Default Re: ***Did I Blow my Head Gasket?? Please help!*** (EM-One)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EM-One &raquo;</TD></TR><TR><TD CLASS="quote">Sup fellas--I have a 2000 Civic Si w/a Greddy Turbo kit, and this morning when I started my car, it idled fine for about 45 sec, then my idle dropped super low where it was on the brink of stalling, and when I stepped on the gas to bring the RPMs up, it would sputter and sound like a diesel, and had difficulty revving past 4k.
I want to get a leakdown/comp test, but I'm afraid to drive my car--will it be ok to drive, or should I tow it to some place?? Does this sound like the head gasket? And if so, do I need to replace anything else, or should that be it? Thanks for the help! </TD></TR></TABLE>
it sounds like a headgasket to me. have a compresion test first. you don't have to take it to a shop to have it done.
if you're afraid to drive the car, borrow or have someone take you t a part store. pick up the tester and do it yourself.
http://www.c-speedracing.com/h...n.php (leakdown)
http://www.c-speedracing.com/h...t.php (compression)
good luck.
Old Aug 2, 2007 | 11:17 AM
BlackoutVTi's Avatar
Have the headgasket replaced, since that is most likely the problem, given the symptoms. Sorry to hear that dude
Old Aug 2, 2007 | 11:24 AM
EM-One's Avatar
Default Re: ***Did I Blow my Head Gasket?? Please help!*** (BlackoutVTi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlackoutVTi &raquo;</TD></TR><TR><TD CLASS="quote">Have the headgasket replaced, since that is most likely the problem, given the symptoms. Sorry to hear that dude </TD></TR></TABLE>
Thanks man, yeah, I'm super bummed right now, especially b/c I just got layed off from the mortgage company I was working.
What is a fair price of labor I should pay to have it replaced? (Some dude quoted me $270) Do I need to replace anything else when I change out the head gasket?
Old Aug 2, 2007 | 11:27 AM
philosofy1's Avatar
What is a fair price of labor I should pay to have it replaced? (Some dude quoted me $270) Do I need to replace anything else when I change out the head gasket?</TD></TR></TABLE>
well, if it hasn't been done yet, i would recommend you replacing the
water pump
timing belt
timing belt tensioner
cam seals.
but with your unfortunate situation, i would just do the headgasket. the others can be done at a later time and most likely you can perform them.
Old Aug 2, 2007 | 11:51 AM
EM-One's Avatar
Default Re: ***Did I Blow my Head Gasket?? Please help!*** (philosofy1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by philosofy1 &raquo;</TD></TR><TR><TD CLASS="quote">
water pump
timing belt
cam seals.
Yeah, I would like to change the timing belt, water pump, etc, but b/c of the whole lay-off crap, I have to wait to do that until I come up on some more cash. Thanks for the info, bro. I appreciate it.
Old Aug 2, 2007 | 11:54 AM
That's okay. The only real labor-intensive part would be the headgasket. Most of the rest of those only require some time under the car, so don't worry about them at a time when money is tight.
Cole LaFleur
Jul 11, 2014 09:04 AM
tony7626
Apr 9, 2009 11:29 AM
Frost_1097
Jun 18, 2007 07:21 PM
.adam.
Apr 16, 2006 10:57 PM
00b18b
Jun 15, 2004 05:55 PM
