94 accord brakes sticking big problem
Old Aug 2, 2007 | 07:52 AM
Andryzzle's Avatar
Default 94 accord brakes sticking big problem
Everything was fine until i left my neighborhood.... I start to accelerate and i hear what sounds like a loss of pressure, then the squeeking starts. I pull off to try to find out what could be making the sound but i couldnt see any wear on the wheels or anything else. Squeeking is an understatement, its more of a screeching metal on metal. Anyway, i took the car back home decided it was something in the drivers side front wheel that was making the sound. Today i jacked it up and found that my brake pad is resting on my rotor. The wheel cannot spin freely without making this screeching sound. Because of the sound i heard at first, i dont know if just replacing the pads and rotors will fix my problem. Anyone care to share some insight?
Old Aug 2, 2007 | 12:24 PM
slomob18b's Avatar
Default Re: 94 accord brakes sticking big problem (Andryzzle)
It is possible that the caliper is seized. You can either buy a repair kit or a new caliper. Also check your brake fluid before anything.
Old Aug 2, 2007 | 04:17 PM
1cpu's Avatar
if the caliper was sezied the sound would slowly go away, are you sure they are not the self indicators?
Old Aug 2, 2007 | 05:07 PM
Andryzzle's Avatar
Default Re: (1cpu)
the sound went away.. i took off my wheel and started to spin the hub by hand and it stopped.. i put the wheel back on and drove it around.. no problems.. it didnt pull when i hit the brakes or anything... no more sounds after driving it around. so the caliper could be seized.. is there any way i could find out for sure?
Old Aug 2, 2007 | 05:18 PM
hondaccord's Avatar
Default Re: (Andryzzle)
try pulling off the pads and lightly sanding them. they might be glazed, this happens a lot with semi-matelic pads. the thing that makes this different is that it is all the time not just when breaking, but not all the time.
dlowdog
Dec 15, 2007 10:19 AM
gsl_05
Jul 25, 2007 04:47 PM
Funkin Flux
Jan 25, 2006 05:43 PM
vietboixstunnah
May 10, 2003 01:00 PM
cracker099
Sep 6, 2002 05:57 PM
