Brake question
Old Aug 2, 2007 | 07:01 AM
Stuartz's Avatar
Default Brake question
Whats the thickest disk you can fit in the 5th gen h22a brake calipers ?
What 300mm+ disk will fit the 5x114 pattern
Old Aug 2, 2007 | 12:31 PM
MLBZ521's Avatar
Default Re: Brake question (Stuartz)
Why do you want a thicker Rotor....??? I don't think that's going to increase brake torque..
Old Aug 2, 2007 | 12:38 PM
Eddiebx's Avatar
more heat capacity. but as far as i remember they are 23mm stock, so i would imagine u could squeeze up to a 25mm or so inthere before it hits the brackets.
if u really want to run a thicker rotor swap out to nsx or legend calipers, and then u can run 28mm rotors.
Old Aug 2, 2007 | 12:40 PM
MLBZ521's Avatar
Default Re: (Eddiebx)
^^Exactly.. I knew the Legend Calipers were 5mm thicker, the NSX's are as well?
Old Aug 2, 2007 | 05:26 PM
user 9782082308's Avatar
Default Re: (MLBZ521)
Go here for rotor specs: http://www.dba.com.au/2006/catalogue_intl.asp
Thicker rotor has more heat capacity allowing you to press the brake pedal harder without fade, thus leading to more brake torque.
Old Aug 2, 2007 | 07:09 PM
Eddiebx's Avatar
Default Re: (racerx)
well i dont think it will really generate more brake tq right off the bat, but it will surely hold off brake fade longer than a thinner rotor can.
i think if u compared it cold to cold, u'd probably generate the same tq, i would imagine?
Old Aug 2, 2007 | 07:10 PM
Eddiebx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MLBZ521 &raquo;</TD></TR><TR><TD CLASS="quote">^^Exactly.. I knew the Legend Calipers were 5mm thicker, the NSX's are as well?</TD></TR></TABLE>
yes from what i rmemeber the nsx are 28mm also. well atleast the older ones are, but i would think the newer ones are atlesat 28mm thick too, unless they incresaed the diameter even more
NegativeLift
12
Mar 23, 2011 04:40 AM
Fatcobra
Mar 27, 2007 11:45 AM
bostoncal
Oct 21, 2005 07:01 PM
Soon_2b_evil
Feb 4, 2004 07:12 PM
