help
Old Aug 2, 2007 | 06:37 AM
jdmcivicracer89's Avatar
Default help
ok im changing the tranny fluid on my 2000 si now and when i opened the plug only a few dropps of fluid came out. was i low on fluid or do i have 2 do somethin 2 drain it.
Old Aug 2, 2007 | 06:45 AM
Default Re: help (jdmcivicracer89)
anyone??? im actually doin the flush now.
Old Aug 2, 2007 | 07:39 AM
giddyup21's Avatar
first, there's a topic line for a reason. you'd have had a reply a lot faster had you used it properly.
second, you're either using the wrong drain plug, or your transmission is prolly fuked. just pulling the plug it should pour right out, it's essentially very close to 10w-30 motor oil. drain what is there and refill to spec.
if you jacked your front passenger side up, that could cause the fluid to stay in the transmission i think, but that'd be pretty obvious.
Old Aug 2, 2007 | 07:50 AM
egsleepercivic's Avatar
did you remove the drain plug or the fill plug, the drain plug you just stick a 3/8 rachet with no socket to remove it
gl
Old Aug 2, 2007 | 08:06 AM
wiZCo's Avatar
Stouts 'n' Scotch
Default Re: (egsleepercivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egsleepercivic &raquo;</TD></TR><TR><TD CLASS="quote">did you remove the drain plug or the fill plug, the drain plug you just stick a 3/8 rachet with no socket to remove it
gl</TD></TR></TABLE>
x2
If your trans was bone dry, you'd know it when you were driving.
And yes, in the future, try to make a better title than just "help".
Old Aug 2, 2007 | 08:11 AM
Syndacate's Avatar
Is it jacked up level?
It can't be jacked up on an incline. Needs to be a lift or four jack stands/ramps.
If there was no fluid in it it'd be grinding like a *****.
Other than that make sure ur removing the drain plug - take a picture of the plug you removed and somebody could tell you which it is.
Old Aug 2, 2007 | 03:27 PM
Default Re: (Syndacate)
i had the wrong plug for draning. i drained it now but it wont go in now. i put it in the top hole and it just spills out
Old Aug 2, 2007 | 03:32 PM
mustang5.slow's Avatar
* B A N N E D *
Default Re: (jdmcivicracer89)
just have patience the thick takes time to go in.
jgsmith0928
Honda Civic (2006 - 2015)
Sep 17, 2018 05:13 AM
Andrew14
21
Jun 28, 2010 01:12 PM
VtecAdvantage
Mar 30, 2010 10:10 PM
vics_si
Aug 4, 2005 04:47 PM
RA61825
May 12, 2004 01:15 PM
